Fuel Tank Only Filling up to 7/8 - Page 3 - Chevy Malibu Forum: Chevrolet Malibu Forums
 22Likes
post #21 of 140 (permalink) Old 07-21-2016, 03:04 PM
ctrider's Avatar
Re: Fuel Tank Only Filling up to 7/8
My gauge never shows full, but I bet it's just not calibrated right; I bet the tank is full.
ctrider is offline
post #22 of 140 (permalink) Old 07-21-2016, 04:41 PM
It's not only gauge that's incorrect.
System calculates miles to empty based on 11 or 11.5 gallons instead of 13.
So if I fill up the tank it shows for example 330 miles to empty instead of close to 400 based on 30 miles per gallon fuel economy.
Most of the time I calculate it manually when tank is filled ( as I mentioned before, I was never able to put more than 10.5 gallons even with few miles left to empty ) and it clearly shows miles to empty per incorrect fuel gauge instead of real gallons in fuel tank.
Yes, otherwise I could really care less if I see full tank or 7/8th
Again with long commute it does make a difference how often you stop and waste your time at the gas stations.
I suppose I could just keep driving and record total milage until car runs out of gas, but not sure if I want to do that.
16LT is offline
post #23 of 140 (permalink) Old 07-21-2016, 04:55 PM
But that's what I'm saying: in essence there is no difference, it's just that in your mind you have more gas available to you than your car is telling you. If you put in 11 gallons and it bases its miles to empty on the 11 you put in then there is no issue, you have a couple extra gallons that your car is keeping in reserve. That's not really a GM or dealer issue, then.
Is your fuel guage not showing full after you fill up? That would be a calibration thing then and I get that. But if it "holds" 2.5 gallons in "reserve" it doesn't want to tell you about I get that too. As stated driving until empty is a bad thing.
I'm not trying to be a jerk here, just hoping to give you another view at it. Unless you run it dry you'll never know for sure and are simply guessing it's off. My guess is you'll find completely empty it's 13.5 gallons but the gauge will be far below empty at that point.
miweber929 is offline
post #24 of 140 (permalink) Old 07-21-2016, 05:35 PM
I see your point and some people could care less, if they can do 50 or 80 more miles per fill up.
My point is exact opposite - I want to get as far as I can on fuel tank ( without running out of gas of course ), and hidden 1.5 or 2 gallons in tank are useless.
Can't risk every time when low fuel light comes on hope I still have more gas vs on board display.
I mean we are in 21st century and that stuff should work properly as it has been around for more than 30 - 40 years.
SirNick likes this.
16LT is offline
post #25 of 140 (permalink) Old 07-21-2016, 07:44 PM
If I were to sell you a car and tell you that it had a gas tank capable of 15 gallons and every time you filled up it took 15.0 or fewer gallons, you would probably think that you were running it dry or close to it. But what if I knew that it held another 5 gallons to ensure the fuel pump was always bathed in cooling fluid? That means that it's actually a 20-gallon tank, but only 15 can be used safely.
I think the same thing applies here. You bought a car with a tank that says "X" number of gallons (like the 20-gallon tank above), but you keep filling it with only 11 gallons (more or less), which means that about 2 or 3 gallons is kept from appearing on the fuel gauge, yet it's still in the tank. It's acting to preserve the fuel pump from an early grave, and you from an early and expensive repair. Just because it can hold more than you pump into it doesn't mean you can run it dry and expect to keep driving without a failure.
In my old 20-gallon aquarium, some of the volume was consumed by rocks and filter media. The rest was water and I'll wager that it was less than 17 gallons. I never filled it to the top, and never used it without rocks and filters.
post #26 of 140 (permalink) Old 07-22-2016, 01:30 PM
Just filled up my 2LT with the 2.0T until it clicked then rounded to the next $0.05. App says I have a full tank with 15.0 gallons in it; pretty sure I read the 2.0's got a 16.5 gallon tank.
Seems to me GM is trying to do this on purpose.
post #27 of 140 (permalink) Old 07-22-2016, 03:20 PM
campb292's Avatar
The snazzy 2.0L is specified to have a 15.8 gal tank.
I had already commented on this back on page 1, but seeing it resurface I had been waiting to run to the low fuel light. I just I pumped 11.1 gal in my 1.5L a few miles after the low fuel alert. The app reported 12.8 gal and DIC reported a range of 416 miles. I didn't do any pumping after the first click.
While I see nothing wrong on my end, I will never pass on the chance to furrow my brow at the pitiful but manageable tank size in these 2016 Malibus.
campb292 is offline
post #28 of 140 (permalink) Old 07-22-2016, 05:01 PM
ctrider's Avatar
It's all about weight reduction, I would guess. The manufacturers are all under pressure to get mpg's up. Look at how light the hood is, and the rear lower control arms have holes in them. We have all read about it being close to the Cruze's weight. If the car holds 20 gallons of fuel, that will surely affect weight/mpg ratings.
Personally I don't mind. I do a lot of traveling and I've averaged 40mpg over the 1st 5600 miles. If I need to stop a few more times back and forth to work, I don't mind if I'm going to save in the long run.
ctrider is offline
post #29 of 140 (permalink) Old 08-29-2016, 05:50 PM
Malibu2016LT1's Avatar
This happens to me also, I have only filled up twice since buying the car.
The gauge reads full inside the vehicle, however, the onstar app only reads 90% 7/8........
Sent from my SM-N920V using Tapatalk
Malibu2016LT1 is offline
post #30 of 140 (permalink) Old 08-30-2016, 07:56 AM
ctrider's Avatar
My gauge has actually gotten better. I'm at 8500 miles. I just noticed that it shows full on the dash last night. I'm wondering if the sending unit just needed to be loosened up a bit.
ctrider is offline
Gas tank not filling completely abehmlander General Discussion (Generation 8) 18 07-08-2016 08:02 PM
Fuel Tank capacity, low fuel light Griz General Discussion (Generation 8) 5 12-02-2015 03:14 PM
How big is the fuel tank? bingo296 General Discussion (Generation 8) 2 07-16-2012 08:50 PM
Fuel Tank not full Crop Circles Problems/Service Issues/Troubleshooting (Generations 5 & 6) 4 04-19-2012 05:28 AM
Fuel tank replacement 2ndchancemalibu Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 07-03-2011 01:44 PM
