how to: change the rear bulbs/remove tail lamps - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 1 (permalink) Old 09-18-2009, 12:00 PM Thread Starter
Yefeng's Avatar
Ok, I didn't take pictures of the whole process because im too lazy however I will give you the basic hint on what to do
TOOLS Required:
Flathead screw driver and pliers or a plug remover
First you need to remove these plugs from the side you want to change the bulb/replace the tail lamp
After you remove those you need to twist off the two plug/holder/god knows what to call them things that hold up the net:
After you remove those, pull the carpet back and there you have to unscrew three plugs that hold the tail lamp on, they are twist off so it's very simple~
And then there you go, Finished.
08 LT blue/ebony suede
200k miles on, dents and dings, door lock actuators broken and debadged.... bought new in 08
16 LT Blue/black leather
Con pkg, int pkg, opt.18" (currently 600miles on odo)
Yefeng is offline
LTZ tail lamps on LT done!~ Yefeng Modifications (Generation 7) 19 04-06-2011 10:18 AM
how to: remove the front reading lamps Yefeng Do It Yourself Maintenance (Generation 7) 3 10-09-2009 09:29 AM
WTB: LTZ LED tail lights/bulbs Bluemobile Trading Post (See rules before posting an item for sale!) 1 03-21-2009 06:51 PM
How do you remove the rear deck of a 2009 2LT RichBastrd Modifications (Generation 7) 0 03-05-2009 03:29 PM
Amber rear turn signal lamps savannah_wants_a_bu General Discussion (Generation 7) 1 08-10-2008 10:28 PM
