09 Front Hub/Bearing Replacement - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 15 (permalink) Old 03-29-2011, 01:19 PM Thread Starter
So my 09 is out of warranty and my front drivers side wheel bearing is making a pretty bad sound. I picked up a new timken bearing, but does anyone have access to a repair manual or GM's instructions for replacement?
I know the gist of it (replaced one on my previous car) but torque specs etc. would be nice.
Thanks!
BoarderPH is offline
post #2 of 15 (permalink) Old 03-29-2011, 03:55 PM
Re: 09 Front Hub/Bearing Replacement
Depending on your mileage the powertrain warranty covers the wheel bearings, not bumper-to-bumper. If you are out of powertrain then I can get the instructions on how to replace it.
post #3 of 15 (permalink) Old 03-30-2011, 04:07 AM Thread Starter
I don't know why I didn't think of that, but I am still under 100k. I'll give the dealer a call today, thanks!
post #4 of 15 (permalink) Old 04-26-2011, 05:03 PM
dumb question, I'm looking to replace my pads and rotors all around. Is the hub/bearings part of the rotor assembly (as in, I will have to replace them too) or can someone fill me in on how that works?
Old Car: 2007 Saturn Ion Redline (Sold)
Current Car: 2009 Chevrolet Malibu LS
Darkvette is offline
post #5 of 15 (permalink) Old 04-26-2011, 06:06 PM
The rotors are separate from the hubs/wheel bearings. To be sure, though, contact your auto parts dealer. You may also want to check around online. You might be able to score some slotted and/or drilled rotors for about the same price as stock flat irons. The slotting/drilling allows the gases created during stopping to vent more efficiently, and help with cooling.
post #6 of 15 (permalink) Old 04-26-2011, 07:37 PM
No question is a dumb question if you learn something from it. The rotors are separate from the hub assembly. It is really easy to do brakes on the malibu. Don't forget to pump the brakes afterwards, I have seen some bad things happen when people forget to do that.
post #7 of 15 (permalink) Old 04-27-2011, 11:38 AM
Thx .
That is awesome news btw. The main reason I asked is because before this, I had a Saturn Ion Redline, and the front hubs/bearings were all part of the rotor. It was a pain to change out the front rotors on that thing. Good thing this one is easier to do....
Thx for the response guys.
post #8 of 15 (permalink) Old 05-09-2011, 04:04 PM
Last of the dumb questions. What size is the socket needed to get off the rotors? I'm thinking 35mm?
post #9 of 15 (permalink) Old 05-09-2011, 05:07 PM
If you can drive the car, go to AutoZone. They'll loan you a tool for free. All you have to do is "buy" it with your credit card and then return it for a full refund. They don't do it on new tools, only on their loaner sets. I also borrowed a 1/2" drive breaker bar. Did a friend's 2001 Impala hub/bearing and that made it a cinch!
post #10 of 15 (permalink) Old 05-19-2011, 07:59 PM
Darkvette, to get the rotor off, and only the rotor, you don't need to take the spindle nut off. I know on some cars where the hub and bearings are part of the assembly you have to, but in this situation just remove the wheel, remove the caliper (make sure you hang it from the suspension with thick wire), remove the caliper mount bracket, and then you should be able to get the rotor off. Basically the rotor is held on by the wheel which is held on by the lug nuts.
Don't forget to use some brake cleaner for the new rotors to get any machining grease off, and make sure you get the hub clean and free of rust before you put the new rotor on.
dennisk is offline
How-To: Fender Turn Signal Lamp Replacement Starship How-To/Write-Ups (Generation 7) 3 03-03-2014 06:16 PM
How-To: Front Floor Console Replacement Starship How-To/Write-Ups (Generation 7) 27 03-24-2013 01:09 AM
Hub bearing assembly Bradford2185 Do It Yourself Maintenance (Generations 5 & 6) 3 01-30-2011 08:20 PM
2001 Chevy malibu front wheel bearing retho78 Do It Yourself Maintenance (Generations 5 & 6) 24 06-04-2010 08:39 PM
front parking bulb replacement rob190 Do It Yourself Maintenance (Generation 7) 9 09-07-2009 11:30 PM
