09 malibu drivers side headlight went out - Page 2 - Chevy Malibu Forum: Chevrolet Malibu Forums
post #11 of 20 (permalink) Old 08-23-2011, 10:45 AM
Re: 09 malibu drivers side headlight went out
Dear blackandchrome,
I have read your post. Please, let me know what the outcome is of your visit to the dealership.
post #12 of 20 (permalink) Old 12-09-2012, 09:08 AM
This is getting to be rediculous! My low beam headlight on the passenger side is out and my 3rd brake light is on when not being used. My battery died a month ago and locked me in the car. Chevrolet you are really letting me down!!! I have a 2009 Malibu LTZ it is a beautiful car but starting to be a thorn in my side.
ElderNurse is offline
post #13 of 20 (permalink) Old 12-09-2012, 01:31 PM
Pulling the front bumper off on the malibu is quite easy. I can have it off in less than ten minutes. And it can be done on the ground. A bunch of push pins and some 10mm boltd and 7mm bolts. You dont have to remove the wheel house liner just the push pins that hold the liner to the bumper. I havent seen a bad connector on the malibu yet but have seen them on the saturn outlook. Bulbs do burn out they arent made to last like they use to... I had a 90 cadillac with over 140k on it still the original bulbs (i sold it in 08).
daveyio87 is offline
post #14 of 20 (permalink) Old 12-10-2012, 08:17 AM
I’m sorry to read about your frustrations with your Malibu, ElderNurse.
The low beam head light is a maintenance item.
Under normal circumstances your concerns with the brake light would be covered under the Bumper to Bumper limited warranty. If you would like me to research the warranty information for your vehicle please, send me a private message with the VIN.
post #15 of 20 (permalink) Old 12-22-2012, 02:13 PM
The brake light issue is addressed in a post in this very sub-forum.
Your car cannot lock you in, you can pull up on the lock and let yourself out.
It's almost 2013 accounting for the fact that your car was likely assembled in 2008 and your battery before that even your battery is probably pushing 4-5 years old, probably time for a new one, factory batteries rarely last longer than 5 years.
Headlight bulbs are a maintenance item. Again, 3-4 year old bulbs, time for new ones.
Only one of these is abnormal and out of specs but a fix has already been found and it's a matter of reseating connectors and possibly a little dielectric grease. No need to cry wolf.
Dilatory is offline
post #16 of 20 (permalink) Old 12-27-2012, 02:36 PM
The low beam headlight under normal circumstances would be maintenance issue, but after buying the replacement bulb the old bulb started working again and after that it was on and off. It ended up being the wiring harness. This is repaired now. The battery was understandable and replaced promptly. I was locked in the car because there has been a issue with the door hanging and pulling up on it on the driver's side front did not release the lock. All is well after all I love it and even roses have thorns but we try not to get pricked by them while enjoying their beauty. Eldernurse aka Little Red Riding Hood
post #17 of 20 (permalink) Old 12-28-2012, 09:54 PM
Well, at least you have a sense of humor about it xD
Glad you got everything worked out, nothing is without its kinks. For all the flack people give GM I really think they get most things more or less right, just have to rub your car the right way sometimes.
With that said, the bumper design IS a bit goofy but, once you do one side, the other side and repeated removals really aren't that difficult. Did one side in about 40 minutes the first time I attempted it and can do each side in 15-20 now. It's something that has to be dealt with every few years but ultimately it's not a deal breaker.
Dilatory is offline
post #18 of 20 (permalink) Old 06-14-2013, 05:58 AM
I have an 09 Malibu and like I see on here the driver side bulb keeps going out. When I opened it up again, I noticed the socket that the bulb plugged into was melted on one side. I went to Autozone and purchased a replacement socket. The factory socket had 3 wires (1, yellow, and 2 black). The replacement socket from Autozone only as 2 black wires coming from it... How do I wire this socket up?
RMal is offline
post #19 of 20 (permalink) Old 06-14-2013, 08:39 AM
The 2 black wires on the factory socket are spliced together inside the socket.
When you cut off the old socket splice the 2 black wires along with one of the wires from the new socket together. Splice the yellow wire to the other wire from the new socket. FYI the black wires are ground and the yellow wire is the switched 12 V.
Make sure your electrical splices are mechanically solid, solder them if possible. Also make sure the splices are weatherproofed. If you don't you will be doing this again sooner than you want to.
For maximum bulb life do not touch the glass portion of the bulb with your bare hands, use a clean rag or paper towel. Some dielectric grease on the bulbs contacts is not a bad idea either.
dc2009 is offline
post #20 of 20 (permalink) Old 08-19-2013, 06:40 PM
Cizzle714's Avatar
How do you get the front bumper off in 15-20 min and without pulling back the wheel well shroud? There are 2 bolts on each side that hold the bumper to the front fender.
Cizzle714 is offline
08 Malibu Headlight Bulbs asoriano Modifications (Generation 7) 20 08-09-2011 07:58 PM
SIR Disabling for drivers side door replacement williamcarr03 General Discussion (Generation 7) 5 07-25-2011 11:55 AM
malibu headlight Malibu25 General Discussion (Generation 7) 5 04-26-2011 09:51 PM
2010 Malibu "Clunk/Thunk" in Drivers side window LT1Malibu General Discussion (Generation 7) 0 01-26-2011 03:58 PM
Minor scratches on 2010 LT drivers side window want it right Washing, Waxing and Detailing 2 06-13-2010 10:38 AM
