Is it easy to replace the brake pads on your own? - Page 2 - Chevy Malibu Forum: Chevrolet Malibu Forums
post #11 of 18 (permalink) Old 05-25-2012, 06:42 AM
vachevy09's Avatar
Re: Is it easy to replace the brake pads on your own?
Originally Posted by vettenuts View Post
I finished installing Centric Street Performance pads and their e-coated high carbon rotors. The parts looked very good and fit well, but I wasn't fond of the rotors being built in China although my last GM rotors were also made there.
I think all rotors are made in China now days.
vachevy09 is offline
post #12 of 18 (permalink) Old 05-28-2012, 05:53 AM
That is unfortunately truly disappointing.
vettenuts is offline
post #13 of 18 (permalink) Old 06-26-2012, 05:23 AM
mos
i am replacing mine now, freeing up the bolts is really the only hard part. not much room to get in there and when the bolt pops loose, you cut your hands, or my finger lol. anyhow, returning the piston to it's home position, with my home made socket, actually is a nice change. not having to use a clamp to push the piston back in. so assembly of the new set works like a charm.
mos is offline
post #14 of 18 (permalink) Old 01-23-2013, 01:19 PM
Does anyone have the torque specs for the caliper bracket bolts and slide pins for a 2009 LS?
IffyG is offline
post #15 of 18 (permalink) Old 01-23-2013, 05:58 PM
If a nut wont pop make sure you're using the correct sized 6 point socket and set it up so you can get a big conventional wrench on the end of your ratcheting wrench and use it as leverage. Or put on a decent pair of gloves and hold the socket on with one hand while winding up and smacking the end of the wrench with your palm. Or get a 3/8ths drive air ratchet wand with 150-200 lbs of torque and giggle your way through the entire process.. As for torque specs I know I should do it correctly but I've always just tightened it until I can't turn it anymore and then given it two good smacks with aforementioned palm technique and I've never had any issues, BUT, not exactly manufacturer recommendation.
Edit: Stolen from another thread 7th gen torque specs
Caliper Bolts - 26 ft - lb
Wheel Lug Nuts - 100 ft - lb
Dilatory is offline
post #16 of 18 (permalink) Old 08-29-2015, 04:59 PM
Post Re: Is it easy to replace the brake pads on your own?
Need to replace rear pads for malibu 2013. Need to compressing the caliper piston????? Really hard!!!
please help!!
Mustafa is offline
post #17 of 18 (permalink) Old 08-29-2015, 06:15 PM
Drunken Elvis's Avatar
Usually the pistons in the rear calipers can be retracted or turned back by using a simple pair of needle nose pliers.
Drunken Elvis is offline
post #18 of 18 (permalink) Old 08-30-2015, 07:32 AM
the proper tool is a rear disc caliper tool set
http://www.amazon.com/OEM-27111-Disc-Brake-Tool/dp/B00062ZO5S
Paul - 2010 Malibu
TheSilverOne is offline
brake pads and rotors jeffsu350 Do It Yourself Maintenance (Generations 5 & 6) 37 07-24-2012 04:40 PM
What type of brake pads? onecrazyfoo4u Do It Yourself Maintenance (Generation 7) 33 10-22-2011 03:11 AM
Brake Pads nertil1 Do It Yourself Maintenance (Generation 7) 20 09-08-2011 06:45 AM
Brakes, time to replace those pads. elcompaLalo Do It Yourself Maintenance (Generation 7) 10 07-05-2011 09:48 AM
Questions on: Rear Brake Pads/Drums, Parking Brake Cable and PS. vtcarol50 Do It Yourself Maintenance (Generations 5 & 6) 5 10-28-2010 09:17 AM
