remote start - Chevy Malibu Forum: Chevrolet Malibu Forums
 1Likes
post #1 of 14 (permalink) Old 01-07-2017, 04:45 PM Thread Starter
remote start
Just purchased a 2014 Lt. So far so good, but when I used the remote, it started and when I got in the car, I couldn't shift out of park. I had to turn off and start again. Is this normal??
Gustav14 is offline
post #2 of 14 (permalink) Old 01-07-2017, 07:22 PM
Re: remote start
Absolutely not normal. I have a '13 and made them install factory remote start as part of my deal. I've never had that issue. As mine was also certified if I had that issue it'd be going back tot he dealership post haste for lookyloo immediately.
13 LT
Dark Labyrinth Metallic
Blck/Gry gut
LED Tails
Remote Start
Opt7 HID Lows (6k)
Osram Nightbreaker Unlmtd Highs
LED front/rear turns, lic plate, trunk, dome/map & reverse.
LED DRLs (6k)&fogs (yellow)
Chrome grills
Crbn fbr bows & pillars
22" Dropstar 536 on 235/30ZR22 (Nitrogen filled)
Pin stripes (silver & metallic black)
Limo tint rears
12% tint fronts
Chrome rear reflector trim
Crbn fbr roofline spoiler
Painted calipers (high gloss burgundy)
jctopbro8 is offline
post #3 of 14 (permalink) Old 01-08-2017, 05:14 AM
SilverSport's Avatar
Re: remote start
do you have a key???...you still have to put the key in the ignition and turn it unless you have the dash mounted button. If you have put in the key and turned it and it doesn't allow you to shift out of Park (and you have your foot on the brake peddle to release the shift interlock) then you should get your car looked at.
Good luck,
Bill
SilverSport is offline
post #4 of 14 (permalink) Old 01-08-2017, 07:58 AM
Re: remote start
Good luck,
Bill
You bring up a good point, Bill. LOL. I didn't even think about the gotta put the key in the ignition and turn it aspect as I thought it was just known. BUT, I also had a vehicle previously where I only had to have the key within a few feet of the ignition to put it in gear n go after remote starting.
So, to Gustav14, please forgive my presuming you had actually put the key in the ignition and turned it. Is this your first vehicle with remote start?
13 LT
Blck/Gry gut
LED Tails
Remote Start
Opt7 HID Lows (6k)
Chrome grills
Limo tint rears
12% tint fronts
post #5 of 14 (permalink) Old 01-08-2017, 12:03 PM Thread Starter
Re: remote start
Yes this is my 1st car with remote start. I should have said that when I got in the car I put the key in the ignition and turned to the on position, then tried to shift with no avail. When that didn't work, I turned off and restarted and then I could shift.
Gustav14 is offline
post #6 of 14 (permalink) Old 01-08-2017, 12:16 PM
Re: remote start
Try this:
1. Remote start the car.
2. Get in.
3. Insert key.
4. Turn to ON position.
5. Turn to START position.
6. See if you can now shift out of PARK.
It's possible that the BCM still needs to see the START attempt from the physical key. If so, the programming needs updated. If this works, do it several times in a row to make sure it's not just a fluke, then take it to your dealer and show them.
post #7 of 14 (permalink) Old 01-08-2017, 04:47 PM Thread Starter
Re: remote start
Thanx guys I'll give a try tomorrow(it's to cold out there now).
Gustav14 is offline
post #8 of 14 (permalink) Old 01-08-2017, 09:27 PM
Re: remote start
And info like that is why we like to keep DrivenDaily around these parts!
Let us know how it turns out.
13 LT
Blck/Gry gut
LED Tails
Remote Start
Opt7 HID Lows (6k)
Chrome grills
Limo tint rears
12% tint fronts
post #9 of 14 (permalink) Old 01-10-2017, 06:00 PM Thread Starter
Re: remote start
Well here's the skinny. When in the car with key in, I only turned the key to the ACC position. Simply, I didn't turn the key far enough. I was afraid if I went further it would engage the starter, and that wouldn't be good. I guess it was a senior moment.
Gustav14 is offline
post #10 of 14 (permalink) Old 01-10-2017, 06:49 PM
Re: remote start
I'm sure that on yours it is like it is on mine: If I've used remote start and turn the key past RUN to the START position, it will not grind the starter. I'm not saying to go out and try it, but I'd be willing to bet that it won't grind.
(Ask me how I know ... )
Trying to remote start car - lights flash once, but no start MaloMalibu007 Problems/Service Issues/Troubleshooting (Generation 7) 8 02-24-2015 06:01 AM
Remote Start/ Push button start kbandison Modifications (Generation 7) 4 02-23-2015 07:14 PM
Remote start will not start car - 2004 LT DjSker Problems/Service Issues/Troubleshooting (Generations 5 & 6) 13 02-05-2015 07:09 AM
Remote Start wont start my BU Dman3047 Problems/Service Issues/Troubleshooting (Generation 7) 9 07-20-2011 12:53 PM
installed remote start, engine dies after start tonynikki0181 Modifications (Generation 7) 0 03-12-2009 10:40 AM
