Spare Tire (Everything you wanted to know) - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 7 (permalink) Old 02-19-2016, 10:36 AM Thread Starter
I know there are other threads on this subject but I thought it would be good to gather all the technical information on the spare tire for the Malibu and other options.
Also if you bought a spare tire and made sure it fit, especially in the wheel well then post where you bought it, model #, etc.
I copied the pictures from another member (BruceH)
This is the information I have on the spare tire:
17X4 SPACE SAVER
Continental CST C17
Dimensions:
Size: T125/70 R17 98mm
Bolt Pattern: 5 lug 4.72 inch or 120mm High Positive Offset
Max Load: 1708 lbs
Max. Inflation Pressure: 60 psi
Tread Depth: 3/32”
Tire Weight: 10 lbs
Rim Width Range: 3-4”
Measured Rim Width: 3.5”
Section Width: 5”
Tread Width: 3.5”
Overall Diameter: 24.9”
Revs per mile: 835
Country of Origin: Germany
Other spare tires that may fit the 2013 Chevrolet Malibu:
2008 Pontiac G8
2002 Volvo V70
99-05 Volvo S80
1999-2006 BMW E46
Chrysler 300
ID:	31873   Click image for larger version
ID:	31881   Click image for larger version
tradosaurus is offline
post #2 of 7 (permalink) Old 05-25-2016, 07:45 AM
Re: Spare Tire (Everything you wanted to know)
I went to the local pull-a-part and found a 16" compact spare from a 4th gen Camaro. It's pretty close to the caliper but it looks like it clears. I'll be getting a new tire but i think it was worth the $13.
This is on a 2015 Malibu LS btw.
Blue 07 Malibu LT 3.5L V6
Charcoal 15 Malibu LS 2.5L I4
jrrtt09 is offline
post #3 of 7 (permalink) Old 06-25-2016, 04:00 PM
I finally got a tire on the wheel, it's a 125/70D16, I drove it 2 miles to test it and it seems fine, even though it looks a little small.
Sent from my Nexus 5X using Tapatalk
jrrtt09 is offline
post #4 of 7 (permalink) Old 06-26-2016, 09:39 AM
lionbaseball's Avatar
Are your tires 16 or 17"? Mine are 17" which is why I would go with the 17" spare tire.
lionbaseball is offline
post #5 of 7 (permalink) Old 06-26-2016, 04:22 PM
Mine are 16" with 215/60r16, that tire size is actually used on my 07 as well.
jrrtt09 is offline
post #6 of 7 (permalink) Old 10-23-2016, 09:08 PM
Does the 16" spare fit ok in the trunk?
I think this may be the best option so far since it clears the front brakes. Cost-wise for sure. Although, I may look for a taller spare tire but would worry about it fitting in the trunk.
Firebat is offline
post #7 of 7 (permalink) Old 11-09-2016, 12:28 PM
My 16" compact fit in the trunk just fine, plenty of room for a larger tire.
jrrtt09 is offline
No Spare Tire! Belababie General Discussion (Generation 8) 34 04-17-2017 04:49 PM
Spare tire ydrsbtr97 General Discussion (Generation 8) 68 10-22-2016 06:24 AM
No Spare Tire CoKTM Wheels, Tires & Suspension (Generation 7) 26 02-25-2014 08:11 AM
Applicable Spare Tire? Doug General Discussion (Generation 8) 17 01-16-2014 11:32 AM
Spare Tire KCLTZ Wheels, Tires & Suspension (Generation 7) 13 05-01-2010 04:59 AM
