Does anyone know how turn off lights in the car while door is open? - Page 2 - Chevy Malibu Forum: Chevrolet Malibu Forums
post #11 of 19 (permalink) Old 07-25-2011, 03:04 PM
Re: Does anyone know how turn off lights in the car while door is open?
Originally Posted by cleatus View Post
take out bulb?
Finally, a voice of simple logic and reason.
K.I.S.S.
post #12 of 19 (permalink) Old 07-25-2011, 08:14 PM
Or see if a 6th gen dome housing (with switch) will fit without too much effort, or possibly some other car...
2009 1LT, white on cocoa...
3.5L 4-spd...
closer9 is offline
post #13 of 19 (permalink) Old 07-26-2011, 10:24 AM
Lightbulb Re: Does anyone know how turn off lights in the car while door is open?
Ive seen the switch installation, always wondered which veh they got the dome from, thanks ill try that.. And if that doesnt work, im sure the next suggestion will be to take out the bulbs and carry a flashlight.
MALIBUSKII is offline
post #14 of 19 (permalink) Old 08-26-2011, 11:25 AM
I found that if the door latch asembly closes (as if door closed) the interior light goes out.
oraldlight is offline
post #15 of 19 (permalink) Old 11-11-2012, 06:28 PM
Exactly. Stick your finger in the latch & press down twice till it bottoms out. Then the ajar switch is closed. Then, just remember to use the interior door handle to reopen the latch before closing the door. Easy as cake.
post #16 of 19 (permalink) Old 11-13-2012, 05:53 PM
Poking around, it appears integrated into the door latch mechanism. If I use a screw driver to close the latch,, the light goes off on my '11.
Just remember to lift the handle prior to closing the door...
post #17 of 19 (permalink) Old 05-26-2013, 08:48 AM
Manipulating the latch does not seem like an intuitive solution. Are there other workarounds available that prevents the interior lights from turning on after a door is open?
It would be even better if Chevy created the dimmer switch with an 'always off' setting.
EEEJAY is offline
post #18 of 19 (permalink) Old 05-26-2013, 08:51 AM
Pull the fuse...
post #19 of 19 (permalink) Old 12-25-2013, 11:43 AM
2011malibu will not start battery is good inside lights will not shut off and radio will not shut off even with the out of the ignition
Joep is offline
Door won't latch or open when it is latched... beach Problems/Service Issues/Troubleshooting (Generation 7) 35 04-19-2016 08:10 AM
Door Chime, Turn signal noise Trh179 Modifications (Generation 7) 17 10-14-2015 06:39 AM
Door Handle Lights... Eddiedav General Discussion (Generation 7) 15 03-12-2015 12:57 PM
Brake lights won't turn off and Cruise won't work singleslammer Problems/Service Issues/Troubleshooting (Generation 7) 20 04-02-2014 10:41 AM
Sliding cup-holder door hard to open. slhaas General Discussion (Generation 7) 18 02-03-2013 09:34 AM
