What parts are interchangeable between Grand Am GT? - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 4 (permalink) Old 03-15-2016, 06:39 AM Thread Starter
Long story short... I got screwed over with a grand am I recently purchased and will now be getting a 2000 Malibu with low km from a family member. The Malibu needs some refreshing and regular maitnence bits, but overal pretty good for the year. The grand am is not worth fixing itself, but has a lot of recent parts like all 4 struts, decent brakes (disk in the rear as well), etc. Could these parts be swapped over to the Malibu easily to fix the worn out bits it has, and lessen the loss from the grand am? The grand am is a 2000 GT, would I be able to put the dual exhaust and maybe the top end of the 3.4 on somewhat easily? Or would that require a tune? Malibu has the 3.1. Anything else you could think of worth salvaging?
Thanks guys
Davenkorbo is offline
post #2 of 4 (permalink) Old 03-15-2016, 07:29 AM
mred's Avatar
Re: What parts are interchangeable between Grand Am GT?
I am not a professional mechanic and I do not play one on TV. Double check before you do anything...
BUT...
According to the Monroe Shocks and Struts site, the part numbers for the suspension components mentioned (struts for example) are the same between the 2000 Grand Am and the 2000 Malibu.
2000 Malibu
2000 Grand Am
When it doesn't go your way, think, "Problem, or inconvenience?"
"Franklin" - 2004 Malibu Maxx LT
mred is offline
post #3 of 4 (permalink) Old 08-24-2016, 01:35 AM
Thanks guys
Did you use the rear discs from your Grand Am and put them on the Malibu? If so, is everything working properly and did you notice better stopping with the rear discs in place?
OscarMike is offline
post #4 of 4 (permalink) Old 12-16-2016, 07:24 PM
Basically everything
boggscodey@gmail.com is offline
Are steering wheels (w/ controls) interchangeable? 2005 Neon Blue Malibu General Discussion (Generations 5 & 6) 3 02-23-2016 05:38 AM
Are seat belts and retractors interchangeable? CaelanAk Problems/Service Issues/Troubleshooting (Generations 5 & 6) 0 03-05-2015 11:04 AM
What year fenders are interchangeable? aScionsEnd Do It Yourself Maintenance (Generations 5 & 6) 4 08-04-2013 03:11 AM
Pittsburgh vintage grand prix Hammer General Discussion (Generation 8) 0 07-18-2012 02:50 PM
03' Grand Am Wiring Help?? Willywonka1991 Other Rides 3 09-23-2010 02:56 PM
