2001 Exhaust replacement - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 8 (permalink) Old 10-29-2012, 09:26 AM Thread Starter
Question 2001 Exhaust replacement
I stopped in a muffler shop(national chain) to get an estimate. $800+ so I decided I would tackle it on my own. All the parts are ordered and came in today. I have a question, the three studs on the flange after the cat, are they pressed in? I am guessing they are rusted badly so I will need to replace them. Any insight on this would be great! They rest looks straight forward.
Buckeyert is offline
post #2 of 8 (permalink) Old 10-30-2012, 04:41 AM
Re: 2001 Exhaust replacement
Use some PB Rust Blaster or similar to help break them loose, then you should be able to unscrew them. Basically it's penetrating lubricant with a freeze that creates microcracks and then uses them to get the lube deep down. I've used it on some pretty stubborn stuff and was successful.
post #3 of 8 (permalink) Old 11-21-2012, 08:37 AM Thread Starter
WOW that intermediate pipe with the resonator is a huge PIA to get over the rear suspension.
post #4 of 8 (permalink) Old 02-26-2014, 07:46 PM
have the same problem.... are they BOLTS or RIVETS?.... mine are on connector pipe just before the muffler.... hate to beat on it and find out its threaded
lately is offline
post #5 of 8 (permalink) Old 02-27-2014, 04:48 AM
Bolts for sure.
post #6 of 8 (permalink) Old 02-27-2014, 06:18 AM Thread Starter
three bolts that were not pressed in. Maybe mine was so rusted but the bolts actually sat in a U shaped slot.
post #7 of 8 (permalink) Old 02-27-2014, 10:29 AM
Czechman's Avatar
Don't bother with PB Blaster or Kroil or anything like that, use a torch to get the nut hot and then try again. The heat will expand the nut, breaking whatever bond has occurred between it and the bolt.
Having taken off more than my fair share of rusted bolts/nuts any time you can use heat, do it. If you can't use heat, use Kroil. Oddly enough, when I was in the USAF the guys in the jet engine shop used plain hydraulic fluid.
Good luck and watch your knuckles.
'06 Malibu Maxx SS (My mini-Challenger) (SOLD)
'07 HHR 2LT (HHR= Her Highnesses Ride)
'09 HHR 2LT AA5 (Sold)
'13 Black Dodge Challenger R/T Redline, 6M
Czechman is offline
post #8 of 8 (permalink) Old 02-28-2014, 08:20 PM
Got it out.... It's a pressed in stud, just like wheel studs... Really hard steel.....
Thanks for the replies
lately is offline
2001 BCM replacement fcs Problems/Service Issues/Troubleshooting (Generations 5 & 6) 28 10-22-2013 08:28 AM
Exhaust pictures wanted!! And exhaust questions.. mk1sh1trocket Modifications (Generation 7) 35 05-11-2013 06:33 AM
2001 axle shaft replacement Buckeyert Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 11-21-2012 08:41 AM
2001 knock sensor location and replacement ezko84 Do It Yourself Maintenance (Generations 5 & 6) 3 12-07-2010 10:35 AM
2000: How is exhaust attached to exhaust manifold? silent_surface Do It Yourself Maintenance (Generations 5 & 6) 2 02-28-2010 10:11 AM
