2006 Malibu LT 4door Vapor Canister Vent Solenoid Location - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 2 (permalink) Old 07-17-2013, 09:09 AM Thread Starter
Post 2006 Malibu LT 4door Vapor Canister Vent Solenoid Location
Got a 06 Malibu 3.5L LT and I got a P0449 code. I had it checked at O'Reilly's and it shows up as P0449 CHEVROLET - Evaporative Emission Vent Valve Solenoid Malfunction Intermittent. I have replaced the gas cap and now the dealer is telling me that it is the Vapor Canister Vent Solenoid. Purchased the part for $25 but can not find the exact location. Can someone help me!
PT2722 is offline
post #2 of 2 (permalink) Old 07-17-2013, 11:18 AM
Re: 2006 Malibu LT 4door Vapor Canister Vent Solenoid Location
Right rear of fuel tank, close to where the fuel fill pipe goes into the tank. Have to lower the tank, not remove it, to get access to it. Has a red two wire connector going to it. It snaps on the tank bracket, don't muscle it off. Before you replace the valve, just check the wiring by the EVAP canister, right side of the fuel tank, there's a wiring harness that comes out forward of the canister. Make sure that harness is not damaged.
Gear in this thread - Powered by O'Reilly Auto Parts
AC Vent Issue 2010 Malibu LTZ cavedoc Problems/Service Issues/Troubleshooting (Generation 7) 6 01-19-2014 11:57 PM
ECOTEC 2.4L Oil Filter-Canister Replacement Procedure: SAINT2 Do It Yourself Maintenance (Generation 7) 10 07-05-2013 12:34 AM
1998 Malibu - Shift Solenoid Issue ckfords Do It Yourself Maintenance (Generations 5 & 6) 3 04-12-2013 01:51 PM
2011 Chevrolet MaLibu 1LS Exhaust camshaft Actuator Solenoid wildbill11 Problems/Service Issues/Troubleshooting (Generation 7) 4 11-26-2012 02:09 PM
Malibu-vent shade, in channel for sale wbarr12@comcast.net Trading Post (See rules before posting an item for sale!) 0 12-31-2008 07:25 PM
