2001 Chevy malibu front wheel bearing - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 25 (permalink) Old 05-30-2010, 06:20 PM Thread Starter
Hi,
I just replaced the front wheel bearing on my 2001 malibu, but now the ABS light is staying on. Is there something that I need to reset or could it be that the wheel bearing is defective?
Thanks.
retho78 is offline
post #2 of 25 (permalink) Old 05-30-2010, 06:33 PM
Re: 2001 Chevy malibu front wheel bearing
It's probably ABS wheel speed sensor. Did you remember to connect it the same way as the original?
post #3 of 25 (permalink) Old 05-30-2010, 07:09 PM
The light would go off if there is not an issue with the system. Check to make sure the wiring is hooked up properly, like starship said. If you have an ohm meter or digital multi-meter you can measure to see if the wheel bearing is open internally by connecting to the wires coming off the bearing/sensor. Also, if you know someone with a scan toll that can pull the code for you, then you can see if it is related to the wheel speed sensor before trying to diagnose.
post #4 of 25 (permalink) Old 05-30-2010, 09:17 PM Thread Starter
I do have a scan tool, will scan tool pick up any codes even if there is no check engine light? The ABS light is on and not the check engine light. There was no ABS light before replacing the old wheel beariing. I did connect the wires back, will check it tomorrow and see if there any lose connection?
retho78 is offline
post #5 of 25 (permalink) Old 05-30-2010, 09:43 PM Thread Starter
Okay, I just did a scan with my scan tool and this code came up, P0131 02 circuit low voltage (Bank 1, sensor 1). Isn't that the oxygen sensor? Which side and were? Will this code cause the ABS light to come on?
Thanks
retho78 is offline
post #6 of 25 (permalink) Old 05-30-2010, 09:51 PM
That code is an oxygen sensor code, if the check engine light isn't on that is probably a history code that isn't an issue. Your scan tool probably only pulls codes for the PCM. I don't know if any places like autozone can scan for ABS codes or not; you may have to go to a shop that can pull the code for you. Most likely it will be a faulty sensor in the wheel bearing, but pulling the code saves the time if it ends up being something different.
post #7 of 25 (permalink) Old 05-30-2010, 09:54 PM
P0131 = O2 sensor but no CEL? This must be a pending code, then. It shouldn't have anything to do with the ABS light. It doesn't look like your scan tool has access to the ABS codes.
post #8 of 25 (permalink) Old 05-30-2010, 10:11 PM Thread Starter
That is correct, no CEL and my scan tool did not pick up any ABS codes. I might just check at the connection and also, maybe try using the old wheel bearing and plug it to the system to see if the ABS light turns off.
retho78 is offline
post #9 of 25 (permalink) Old 05-30-2010, 10:17 PM
That's a good idea. That would make things a whole lot easier to test.
post #10 of 25 (permalink) Old 05-30-2010, 10:23 PM Thread Starter
Yep, will try it tomorrow and see what happens. I'll keep you posted. Anyways, about the sensor which side is it and where is it located? I have some trouble sometimes while starting the car, would try to start then nothing, the try again will start up. Could the sensor be an issue. I had changed the plugs, wires and fuel filter about a year ago, because of this, but didn't make any difference. Could the O2 sensor cause this occasional starting issue. Also, battery is in good shape.
retho78 is offline
Need to Replace Wheel Bearing HELP. EvilTimeGod Do It Yourself Maintenance (Generation 7) 18 11-26-2011 09:22 PM
2008 - 2010 Chevy Malibu Wheel Covers - Hubcaps jdetrag Trading Post (See rules before posting an item for sale!) 1 03-04-2010 02:03 PM
wheel bearing assembly problem, maybe? neoga34 Do It Yourself Maintenance (Generation 7) 2 01-11-2010 06:10 PM
What to do to a 2001 Malibu LS? Dsella Modifications (Generations 5 & 6) 1 11-01-2009 07:12 PM
need help with a 2001 malibu!! cute_dorkie General Discussion (Generation 7) 1 03-04-2009 12:44 AM
