Nitrogen vs Air in your tires - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 16 (permalink) Old 12-12-2015, 05:40 PM Thread Starter
Cool Nitrogen vs Air in your tires
I happened upon this video this evening as I was perusing YouTube.
Warning: There is some language but it's kept pretty much under control.
https://www.youtube.com/watch?v=bCnWvMleVD0
So, how do you feel about nitrogen in your tires? Are you for it or do you prefer to use air?
post #2 of 16 (permalink) Old 12-12-2015, 06:42 PM
Drunken Elvis's Avatar
Re: Nitrogen vs Air in your tires
Nice video!
I use air.
Drunken Elvis is offline
post #3 of 16 (permalink) Old 12-14-2015, 09:51 AM
We used Nitrogen in racing. Benefit was less pressure buildup over the course of a run. Less buildup lead to more predictable handling and less dramatic change in handling. Regular air would typically gain approx. 5lbs of pressure, with tire temperatures between 250 and 300*F. Nitrogen under the same circumstances would gain between 2-3lbs. As stated in the video it was a small gain, but over the course of 50-100 laps that could translate to a lot.
Daily driving is FAR from racing, benefit vs. cost is in that situation is no where near what it is in racing. You only need air for tires in your car.
Superpro56 is offline
post #4 of 16 (permalink) Old 12-14-2015, 01:13 PM
gutz's Avatar
Yup, I agree!!!
gutz is offline
post #5 of 16 (permalink) Old 12-14-2015, 05:05 PM
cp-the-nerd's Avatar
I was unaware people were claiming handling and grip advantages. SMH!
2009 2LT V6 Red Jewel
cp-the-nerd is offline
post #6 of 16 (permalink) Old 12-14-2015, 05:33 PM
nutcrunch's Avatar
I started filling mine with Smuckers grape jelly. The handling is incredible and it never loses any pressure through leakage it's just too thick to permeate the rubber.
An added benefit is if you are on a long trip or get stranded and you're hungry just get out there and wrap your quivering hungry lips around the valve stem and enjoy a nice treat.
Thank you and good night!
2015 Impala 2LT
V6 305hp/264tq
Conv PKG
Adv Safety PKG
Sunroof
50/35 Suntek CXP tint
RIP
2013 Malibu ECO 1SA PCN pkg
May 2012-Aug 2015
nutcrunch is offline
post #7 of 16 (permalink) Old 12-14-2015, 05:34 PM Thread Starter
They also claim less oxidation inside the tire and therefore less rotting, less or no rust on rims, fewer issues with TPMS sensors (that actually sounds reasonable!), more stable temps, better handling, better grip, less tire wear, less permeation of the rubber carcass due to a larger nitrogen molecule.
I'm sure I missed a few, but there's a good list to get started.
I'm gonna save my money.
One of the things they didn't really cover in any of the videos I've watched is how to get all of the oxygen and moisture out once it's inside. It just ain't possible to do that without inflating it with nitrogen during mounting.
post #8 of 16 (permalink) Old 12-15-2015, 06:19 PM
When we bought my wife's Subaru, the tires came filled with nitrogen, and for that first 11,000 miles, the tire pressure light never came on, but after the tires were changed and filled with air, I have to watch the tire pressure more closely... The car also seemed to get better mileage with the old tires... I think during the first 5k, it got around 33.5mpg, and now it's down to 31 or so.., maybe she's driving faster though, I'm not sure... I use air(and probably don't check often enough)
19bonestock88 is offline
post #9 of 16 (permalink) Old 12-16-2015, 09:07 PM
Speed_Freak5150's Avatar
I used to use nitrogen and always had better tire pressure stability and tire wear. I won't pay extra for nitrogen so I have been using air. On my old CRX I did see some MPG gains and better handling when switching to nitrogen.
10 Malibu 1LT
'14 Traverse 1LT
Speed_Freak5150 is offline
post #10 of 16 (permalink) Old 12-16-2015, 10:50 PM
I'll happily believe that you got improved pressure retention/stability, but getting better tire wear, handling, and MPG would literally defy physics. Those things are only affected by pressure, and 35 psi is the same 35 psi no matter what gas fills the tires.
Food for thought:
-Improved MPG requires higher air pressure (harder tire = less rolling resistance).
-Improved handling requires lower air pressure (increased contact patch).
-Improved wear depends on the specific tire model's goldilocks pressure.
Nitrogen Tire Pressure Errol Do It Yourself Maintenance (Generation 8) 15 09-18-2013 11:53 AM
Nitrogen or regular old air in your tires? Lgndryhr Wheels, Tires & Suspension (Generation 7) 9 03-21-2011 03:15 AM
Air Pressure - Rear Tires Richard Wheels, Tires & Suspension (Generation 7) 5 09-08-2010 10:35 AM
Replaced the air in my tires with Nitrogen for FREE! Trend1 Wheels, Tires & Suspension (Generation 7) 5 08-23-2010 01:06 PM
Nitrogen in Tires jaymista General Discussion (Generation 7) 15 07-15-2008 09:19 PM
