2010 Chevy Malibu LS - US8 to UUI Radio Swap - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 22 (permalink) Old 11-13-2012, 03:42 PM Thread Starter
All,
This is my first post here so hopefully i don't screw this up. 6 months ago I bought a 2010 Chevy Malibu LS. It came standard with the US8 Radio and I really wanted to get the UUI radio for the USB interface.
I bought the UUI radio (Part #: 20940843) brand new from shopgmparts.com. Install went smooth, I removed the dash panel, swapped the radio and it worked flawlessly. To my surprise, the radio worked without displaying the LOCKED message and it did not require programming. However, I did take it to the dealership to get it programmed thinking they would have to register the radio with my VIN for OnStar to work.
Even though it works ok there are a few quirks: the car chimes/beeps are somewhat softer now, especially the turn signal noise. I did try to toggle the chime sounds from NORMAL to LOUD on the radio but it's still not the same as it was when I had the US8 radio. Also certain chimes do not come on anymore such as when turning the automatic lights off and back on. It's not a big deal but I am wondering as to why this is happening.
The most annoying problem I am having is with FM reception. I get static noise and poor reception in the background constantly no matter where I go or what station I tune in to. AM works fine on the other hand. I am not sure if this is a radio-amplifier issue or the fact that I do not have the BOSE premium sound. Or maybe the dealership did not program it correctly?
I am not sure what to do and how to proceed. I am thinking of just swapping back to the US8 and selling the UUI or selling both radios and going aftermarket unless I fix the radio problems at least.
Anyone have any ideas?? Thanks!
totalitus is offline
post #2 of 22 (permalink) Old 11-13-2012, 06:18 PM
09LT2's Avatar
Re: 2010 Chevy Malibu LS - US8 to UUI Radio Swap
Welcome!
This has been tried a few times on here. Have you noticed the audio volume being quieter too? We figure the root of the problem is that you do not have the amplifier in the trunk. The signal going through your speakers is un-amplified.
I would either go back to stock or go aftermarket!
Mine:
2009 Summit White LT2 3.6L V6
Factory Fog Lights Added
Hers:
2009 Performance Red Metallic Pontiac G6 2.4L 6Spd
Factory Fogs added
Black SPO Upper and Lower Grilles
09LT2 is offline
post #3 of 22 (permalink) Old 11-13-2012, 06:42 PM Thread Starter
09LT2, Thanks for your reply.
I did not notice any problems with volume. I guess you are right about the lack of amplifier, FM transmission is weak and occasionally the signal fades in and out. AM transmission however is not affected.
Does this mean the US8 radio has a built in amplifier and the UUI relies on the premium sound package amplifier? I also noticed that the US8 radio was branded AC DELCO but the UUI radio is a Panasonic.
The reason I am somewhat holding back from going aftermarket is because I like to keep things as stock as possible. Also, it seems that there are a lot of additional harnesses and adaptors to be purchased in order to retain the stock chimes and other features.
post #4 of 22 (permalink) Old 11-13-2012, 06:48 PM
09LT2's Avatar
Yes the UUI relies on external amp. Also, the premium audio systems are bi-amped, meaning there are 4 wires going to each speaker. 2 wires go to the "sub" and the other 2 go to the mid/highs. The basic system uses full range speakers.
Mine:
Hers:
Factory Fogs added
09LT2 is offline
post #5 of 22 (permalink) Old 11-13-2012, 08:21 PM Thread Starter
I have been doing some digging:
http://www.skyroadster.com/forums/f5...44/index5.html
If I understand correctly, it is a matter of programming by using a dummy vin and selecting the option of non amplified sound system. I wonder if this would solve the problem. I would love to call the local dealership and have them at least try but they gave me enough heartache already trying to program the UUI radio the first time.
Any thoughts?
post #6 of 22 (permalink) Old 11-13-2012, 08:23 PM Thread Starter
Here's some additional information:
http://www.kappaperformance.com/foru...p?topic=7537.0
post #7 of 22 (permalink) Old 11-13-2012, 09:16 PM
09LT2's Avatar
Interesting... So you would just need to go to the dealer with a LTZ vin number looks like. Then they can pick which options they want to use
Edit: actually, your own vin should work, seeing as you dont have amplified system. They just need to change the option in the radio for non-amplified.
Mine:
Hers:
Factory Fogs added
09LT2 is offline
post #8 of 22 (permalink) Old 11-14-2012, 07:48 AM
So, I tend to agree that there is more to it than the head unit.
I think the answer is this:
The UUI radio can output either internally amplified speaker outs
Pre-amp level outputs to the auxiliary amp (premium audio option) in the trunk.
This is consistent, because my 2012 1LT has the UUI radio, but NOT the amp in the trunk. My guess is, you don't want to go to the dealer w/ a VIN for an LTZ, because the LTZ has the premium audio, but your ride does not have this option. What you want is a VIN for a car like mine, with the UUI radio, but not the amp in the trunk. Or, maybe it will just come up for them on their scan tool, since a valid option is indeed the UUI radio w/ out the optional amp, the key I think is maybe they need to tweak the model year so that they have an option to program it that way. I know 2012 is a good year, since I have this setup stock. Then again, I may be wrong too.
As for your fuzzy FM reception, my guess is on a loose antenna connection to the head unit when you replaced it. The amplifier we have been discussing here is the power amp for the speakers, not the incoming FM signal. It is possible there is some distortion or whatever since you are driving speakers w/ a pre-amp level output, so I would definitely get it reprogrammed first, before ripping the dash apart again. If that doesn't fix it, I would check the antenna connection.
Mike in Minnesota
Car (Years Owned)
85 Toyota Tercel (1988-1998)
93 Geo Prism (1993-1999)
96 Chevy Tahoe LT (1996-1997)
98 Chevy Tahoe LT (1998-2001)
99 Chevy Venture Ext (1999-2008)
99 Chevy Suburban LT (2001-2004)
04 Chevy Suburban LT (2004-2013)
08 Honda Odyssey (2008-2010)
10 Honda Odyssey (2010-Present)
12 Chevy Malibu (2012-Present)
13 Chevy Suburban LTZ (2013-Present)
Last edited by michaelj3; 11-14-2012 at 08:04 AM. Reason: Added comment on FM reception.
michaelj3 is offline
post #9 of 22 (permalink) Old 11-14-2012, 08:00 AM Thread Starter
Searching around earlier I came across more information.
http://www.skyroadster.com/forums/f2...55/index2.html
It seems from that discussion like the UUI radios may not be built with a pre-amp like the US8 radios are. In that case it would not matter if the radio is programmed for a non-amplified system. Is that logic correct? Anyone else has any input on this?
The other thing I can think of is the fact that the US8 radio was AC DELCO branded and the UUI is a Panasonic. I wonder if the vendor difference also accounts for any technical changes, such as the AC DELCOs having pre amps and the Panasonics not having any?
However from what you are saying michael, If you have the UUI radio and no premium sound package with amp, I may still be able to do it. I will give my local dealership a call later and see if I can have them take a look at it again and re-program my radio. However, I am afraid the answer will be: "Can't be done", as usual. Would you mind if I used your VIN if the technicians decide to try the experiment that you mentioned?
post #10 of 22 (permalink) Old 11-14-2012, 11:06 AM
09LT2's Avatar
Good info here...I didn't realize some newer Malibus have the premium radio without amplifier. It seems as though in 2012 they started dumping some premium options into lower models just to get rid of their back stock of the parts, since new model year for 2013.
Mine:
Hers:
Factory Fogs added
09LT2 is offline
Radio not working Chevy Malibu 2009 israellopez215 Problems/Service Issues/Troubleshooting (Generation 7) 6 06-17-2014 07:44 AM
2005 Chevy Malibu LS DIC/Radio Screen Problem AntiReality Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 08-31-2011 01:20 PM
Does the 2010 chevy malibu 1lt come standard with satellite radio and onstar? tmurray315 General Discussion (Generation 7) 23 08-27-2011 08:24 PM
2010 chevy malibu 2lt herlof Modifications (Generation 7) 3 01-10-2011 05:06 PM
Help on installing an after market radio on 2010 2lt malibu shookonez00 Modifications (Generation 7) 6 09-16-2010 10:46 AM
