2009 service ECM / Traction control - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 17 (permalink) Old 01-15-2013, 12:12 PM Thread Starter
I am having the same problem with my local dealer and the EMC and traction in my 2009 Malibu LS. I was diagnosed by my local dealer that the code was the traction switch and then the map sensor when the problem still existed after changing the traction switch till this day I am having the same problems. Please help...
Reallove is offline
post #2 of 17 (permalink) Old 01-15-2013, 02:24 PM
Re: 2010 LTZ service ECM / Traction control
I would need the actual codes & a more detailed history to be of much help.
post #3 of 17 (permalink) Old 01-15-2013, 03:55 PM
Cool Re: 2010 LTZ service ECM / Traction control
Originally Posted by greenman View Post
Please start a new thread with your issue. Moved to new thread...
Also, I would need the actual codes & a more detailed history to be of much help.
Codes and other pertinent details are needed by techs in shops, too...
post #4 of 17 (permalink) Old 01-17-2013, 10:13 AM
Re: 2009 service ECM / Traction control
Reallove,
If you would like for us to contact your dealership to follow up on this with them, please send us more details (your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation) to the email address in our signature or by private message on the forum.
Sarah (Assisting Michelle), Chevrolet Customer Service
post #5 of 17 (permalink) Old 01-17-2013, 07:38 PM
repairman54's Avatar
I would unplug / plug the ABS module a few times and the same with the BCM and PCM .
With the neg. cable off the battery of course. That fixed a few weird problems with my car.
John
09 Malibu LS
11 Tahoe LTZ
16 Equinox LTZ 3.6
01 FLHR
Ski Doo's & Sea Doo
02 Malibu traded
67 Malibu sold
64 Malibu sold
07 Mustang GT 3 pedals sold
repairman54 is offline
post #6 of 17 (permalink) Old 01-22-2013, 01:30 PM Thread Starter
Originally Posted by Chevrolet Customer Svc View Post
Reallove,
Thank you I sent you a private message.
Reallove is offline
post #7 of 17 (permalink) Old 02-22-2013, 07:40 AM
Send a message via Yahoo to jhines82
I had the same issue on my 2008 2.4 4cyl. Engine would start stuttering, ESC/Traction would disable, and i would get Loss of Power message. Initially I thought it was a transmission problem, but I took it to the dealer and they replaced the Timing Valve Actuator. It seems to have corrected the problem, I havent had any issues since then.
jhines82 is offline
post #8 of 17 (permalink) Old 03-15-2014, 11:19 AM
I have the same problem as described by Reallove. Engine begins to stutter, Reduced Engine Power flashes on the DIC, and the Traction Loss icon also lights up.
The fault code has always been P1682.
To get the stuttering to stop, I would disconnect the battery for about 10 mins, (sometimes 20 mins), and reconnect and start the engine. EVERYTIME this has happened, and I have had to disconnect the battery, I have noticed that the tEmperature of the ECM has been extremely high (burning hot). And the battery too.
I was compelled to change Ignition coils, but he problem still persists.
Unfortunately for me, I have no GM or Chevy dealer here in Ghana to advise.
A friend who is certified to fix Ranfer Rover, BMW, Porsche and Mercedes and has a GM diagnostic equipment diagnosed the fault codes to be P1682 as earlier indicated.
I am losing interest in this car, an 09 Chevy Malibu LT with 77984 miles on the engine.
Your help will be appreciated.
Thanks.
Adeitse is offline
post #9 of 17 (permalink) Old 03-15-2014, 02:25 PM
Have you or your technician friend tried unplugging the BCM (not the ECM)? Search this forum for "fretting corrosion" and read about it before proceeding. You may find it interesting and helpful. What you do is up to you but it never hurts to learn what you can, especially about an issue that could be such a simple fix.
post #10 of 17 (permalink) Old 03-17-2014, 04:17 PM
Thanks DrivenDaily for the direction.
I took the car to my Tech Fiends' garage. Following the procedural guideline on treating Fretting Corrosion on the BCM, he cleaned the contacts on the BCM, and applied the dielectric grease (we got some from he1 pulstar spark plugs).
I took the for a test drive and for 2 hours, it performed well. Suddenly, the engine started stuttering with the "Service ESC" and "Engine Power Reduced" flashing on the DIC.
I took it back for a repeat procedure. The stuttering came back under 1 hour. By this time, I needed to go pick my daughter from school and so could not go back to the garage.
But, I am thinking replacing the Variable Valve Timing Actuator (intake and exhaust) might resolve it.
What do you all think.
Adeitse is offline
Service Traction Control/ ECS Jimmyb1 Problems/Service Issues/Troubleshooting (Generation 7) 16 08-11-2016 07:28 AM
2010 LTZ service ECM / Traction control pinballfixer Problems/Service Issues/Troubleshooting (Generation 7) 3 02-05-2013 03:01 PM
Brake lights on/traction control service on. Budlab Problems/Service Issues/Troubleshooting (Generation 7) 3 10-30-2012 09:57 PM
service traction control PSMITH Problems/Service Issues/Troubleshooting (Generations 5 & 6) 0 07-22-2011 12:25 PM
Service ECS, Service Traction control??? Yefeng Problems/Service Issues/Troubleshooting (Generation 7) 1 08-25-2009 10:28 PM
