2010 cranks but won't start - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 12 (permalink) Old 01-21-2013, 09:58 AM Thread Starter
If car sits more than 6 hrs it will crank but not start. If the gas pedal it pushed to the floor it starts. If the car is warmed up it starts fine. Replaced purge valve and still same problem.
89raggtopp is offline
post #2 of 12 (permalink) Old 01-21-2013, 05:27 PM
Re: 2010 cranks but won't start
I'm no Master tech but that almost sounds like a fuel pump issue.. and with GMs reputation with fuel pumps wouldn't be largely surprising..
Dilatory is offline
post #3 of 12 (permalink) Old 01-21-2013, 05:49 PM
Mongoose's Avatar
If you smell gas when this happens its flooded...may be a no spark issue also.
Frank
2015 SS Auto
2014 Silverado 4x4
Mongoose is offline
post #4 of 12 (permalink) Old 01-23-2013, 04:05 PM
Thread moved from Gen8 to Gen7 section. Watch where you post.
post #5 of 12 (permalink) Old 01-24-2013, 10:09 PM
When you push the pedal to the floor it goes into clear flood mood. So if it starts when you do this I would think that your car is flooding. Maybe bad FPR that is leaking when it sits, I know there was an issue like this with the impalas a few years back. You should be able to take the vacuum hose of the FPR while it's running and it might take a few minutes but if it is leaking you should smell or see fuel. But if it will start when you push the pedal to the floor I would be checking for things that would cause a flood situation.
scott37300 is offline
post #6 of 12 (permalink) Old 01-25-2013, 12:58 AM
Put a gauge on the fuel rail port to check pressure during a cold start. Range should be 50-60psi. A stuck-open purge valve usually pops a code & typically only causes flooding immediately after refueling.
No codes or other symptoms?
post #7 of 12 (permalink) Old 01-25-2013, 01:24 AM
They don't use separate regulators anymore. They are built into the pump assy.
post #8 of 12 (permalink) Old 01-25-2013, 05:52 AM
I didn't know that. What about a leaky injector?
post #9 of 12 (permalink) Old 01-25-2013, 06:31 AM
repairman54's Avatar
Floored gas pedal to get it to start is a symptom of a leaky injector. Leak down test is the diagnosis for that. Fuel pressure gauge attached and seeing how long it holds pressure is the test. Don't know if there is a pressure port on your car though, someone more familiar will know that.
John
09 Malibu LS
11 Tahoe LTZ
16 Equinox LTZ 3.6
01 FLHR
Ski Doo's & Sea Doo
02 Malibu traded
67 Malibu sold
64 Malibu sold
07 Mustang GT 3 pedals sold
repairman54 is offline
post #10 of 12 (permalink) Old 01-26-2013, 11:44 AM
I just looked in the service manual and the 2.4 and 3.6 should have a service port schrader valve.
What is normal for time for the fuel pressure leak down test? Minutes or hours and how much of a drop is normal?
Is a leaky injector something that can be fixed with a good fuel injector cleaner(like what the dealers use) or do you just replace the injector?
Standard Remote Start for 2010 1LT TX Malibu General Discussion (Generation 7) 33 02-22-2012 03:25 PM
2003 Malibu LS cranks will not start when cold mike wiz Problems/Service Issues/Troubleshooting (Generations 5 & 6) 4 12-07-2011 11:37 AM
Cranks But Won't Start stnewton09 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 03-22-2011 07:53 AM
97 6cyl cranks but doesn't start stevegantt Problems/Service Issues/Troubleshooting (Generations 5 & 6) 0 03-16-2011 04:49 PM
2010 2LT Remote Start and Climate Control? savatage General Discussion (Generation 7) 5 10-01-2010 03:06 PM
