marker lights and parking lights wont turn off - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 12 (permalink) Old 07-08-2013, 06:24 PM Thread Starter
My marker lights and parking lights won't turn off even when key is not in the ignition and the only way for me to turn it off is buy disconnecting the battery.Check the video out so you understand.Can someone plz help me.
kingdarius92 is offline
post #2 of 12 (permalink) Old 07-08-2013, 06:56 PM
Re: marker lights and parking lights wont turn off
What position is the headlight switch in? It has 4 positions. At rest it is Auto, one click rearward cancels/sets the Auto feature. One click forward is Parking position. Two clicks forward is Headlight position.
If it's in the Park position, rotate it 1 click rearward.
If the Remote Start has been activated and the engine is running (and the option is set to On) the parking lights will be on until the time expires or you turn the key.
post #3 of 12 (permalink) Old 07-08-2013, 09:11 PM Thread Starter
The headlight switch is turned to auto and the lights are still on even though the car is off
post #4 of 12 (permalink) Old 07-09-2013, 04:34 AM
Pull the park relay under the hood. If the lights go out then swap in another relay from a headlight. If they stay off put the park relay where the headlight relay came out. If the headlight turns on then the relay is welded in the ON position and needs replaced. If the park lights turn on then the relay is being commanded to turn on, which means the BCM may be faulty or there may be a wire (or 2) shorted causing the condition.
post #5 of 12 (permalink) Old 07-09-2013, 11:13 AM
only thing i would add is the park lamp relay is in the rear fuse block in the trunk. a sticky relay is a good bet.
post #6 of 12 (permalink) Old 07-09-2013, 03:43 PM
Oops, didn't catch that - thanks!
post #7 of 12 (permalink) Old 07-09-2013, 04:30 PM Thread Starter
I am novice when it comes to this can you tell me which ones to switch
ID:	6890   Click image for larger version
post #8 of 12 (permalink) Old 07-09-2013, 06:01 PM
First picture, upper left corner, has 8866 in large numbers on it.
post #9 of 12 (permalink) Old 07-09-2013, 06:44 PM Thread Starter
I switched the relays and the same thing is happening so I do not know what the problem is...also Is the parking relay something I can go without for a while..what are all its functions
post #10 of 12 (permalink) Old 07-09-2013, 09:15 PM
then I suggest taking it to a mechanic to sort it out.
rear side marker lights jpackard86 Modifications (Generation 7) 5 04-04-2013 05:51 PM
Front Corner/Side Marker Lights King Air Pilot Modifications (Generation 7) 5 08-15-2011 06:06 PM
make it so your fog lights stay on when turn brite lights on kyleer Modifications (Generation 7) 5 06-05-2011 03:53 PM
I keep blowing a fuse for the dash/marker lights Chris General Discussion (Generation 7) 0 01-30-2010 12:16 PM
Rear side marker lights Dunner General Discussion (Generation 7) 4 03-16-2009 09:57 AM
