Steering/front suspension noises/clunks thread. - Page 52 - Chevy Malibu Forum: Chevrolet Malibu Forums
 1Likes
post #511 of 518 (permalink) Old 10-15-2016, 05:38 PM
Re: Steering/front suspension noises/clunks thread.
jack up the car, remove the wheel and take a look!
Paul - 2010 Malibu
TheSilverOne is offline
post #512 of 518 (permalink) Old 10-23-2016, 07:04 PM
Wow, the plethora of front end complaints is overwhelming - GM should be cringing. I really like the new Malibu, but I'm afraid to look in that forum for stickies and quality problems - and I am a LONG time GM man. I have over 300,000 miles on my 2001 Suburban and had 74,000 miles on my 69 Pace Car until I sold it last year. I have owned dozens of GM cars and never saw problems like this.
I feel for you all trying to work your way through these problems.
My 09 has 217,000 highway miles(by me) and has no clunk. But, it does have a creaking noise while turning the wheel to the left only, and if I happen to be slowly going over smallish bumps at the same time, the creaking becomes doubled, like it is rocking back-n-forth. It makes the creaking noise even when I am in Park and only turning the steering wheel to the left while stationary. It doesn't matter where the wheels are pointing, if I turn to the left the creaking noise occurs for as long as I am cranking - nothing at all if I turn to the right from any position. It has been doing this for 150,000 miles or so. I put Monroe Quick Struts on it several months ago, convinced that was the source. No improvement at all.
I'm intrigued by some posts back on pages 34/35 of this thread regarding the lower control arm/ball joint assembly. But, if it creaks even in Park, doesn't that rule out the lower control arm? ISS? Steering motor? Steering gears?
EDIT:
santa6 is offline
post #513 of 518 (permalink) Old 10-31-2016, 02:55 PM
Any ideas or help appreciated.
santa6 is offline
post #514 of 518 (permalink) Old 11-02-2016, 07:58 AM
I have been taking notes here and there on this issue. The following items are the possible items that people have said to be the origin of the clunking front end. Not that any of them are or the part may not be listed here either.
* Sway Bar Links & Bushings
* Struts & Strut Mounts (Strut mount bearings)
* Intermediate steering shaft
* Lower control arm bushings
* Steering rack-tie rods
* Hub Assemblies
If anyone can give more input, narrow it down, or add another possible problem part that would be great.
'12 LTZ
•Anthracite Grey Wheels
•Anthracite Grey Bowties
•Matte Black Front Grills
•Red Brake Calipers
•Drilled & Slotted Rotors
•20% Window Tint
•10" Alpine Sub
kars2010 is offline
post #515 of 518 (permalink) Old 11-26-2016, 08:43 AM
The vehicle I just purchased came with an inspection form detailing everything they did to recondition the car. This included things like engine and cabin air filters, wiper blades, alignment and tire rotation, oil change, water pump and gasket, and more. One of the lines mentioned "Diagnose Suspension Noise 1.0hr" and the only suspension related parts replaced were "RF inner and outer tie rods". Surprising to already be needed on a 70K mile vehicle, but there it was, and the parts are new underneath.
occupant is offline
post #516 of 518 (permalink) Old 02-07-2017, 02:38 AM
I have an issue with my 2011 Malibu. Whenever I am accelerating hard while turning right from a stop. There is a loud thud which comes from the driver side floorboard. Seems like someone hammered a nail and it just happens only once when I start from a stop while turning right.
Had a rattle for which I changed the stabilizer bar linkage and then had the strut mounts and Lower control arms along with the bearing hubs changed to make this sound go away. But it still persists.
Tried searching for a similar issue but could not find it on the forum. Any suggestions?
shabbu is offline
post #517 of 518 (permalink) Old 02-07-2017, 04:32 AM
2 posts above yours is a list that includes the intermediate shaft. Have you inspected yours or observed it during this situation? Also, what engine do you have, and do you have EPS or hydraulic PS?
post #518 of 518 (permalink) Old 02-16-2017, 07:50 AM
has anyone had issues with power steering going out? thought I hit a patch of black ice but realized I had no power steering and the display panel was lit up like a Christmas tree! pulled off into a parking lot and turned off car. when I turned on back on 20 mins all was fine! still didn't trust it so I had to carpool to work
chriswomo is offline
Steering Questions on 2009 LS (4 Cyl w/electric power steering) Speedster Problems/Service Issues/Troubleshooting (Generation 7) 57 11-11-2015 04:49 PM
Have some steering "noises" when backing up etc? I have a fix! Silver LTZ Problems/Service Issues/Troubleshooting (Generation 7) 8 10-30-2015 04:43 PM
F & R suspension noises driving me crazy (long) vlicona Wheels, Tires & Suspension (Generation 7) 9 03-25-2013 03:36 AM
Need Steering Intermediate Shaft and Left Front Strut cpmman Do It Yourself Maintenance (Generation 7) 7 12-26-2011 12:05 AM
Front Suspension Noise jonemick Problems/Service Issues/Troubleshooting (Generation 7) 86 05-06-2010 12:11 PM
