P0014 Check engine error code - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 50 (permalink) Old 05-10-2010, 04:05 PM Thread Starter
First post on these forums.
Ok so I just got this 2009 Chevy Malibu friday...There are a few issues that I have..But the check engine is by far the most troubling..If anyone has any in sight into what this could be would be appreciated.. THe other problem is my turn signal sometimes sticks...lol
Edit: I have around 39k miles and the oil life is at 24%..
xdirtydogx is offline
post #2 of 50 (permalink) Old 05-10-2010, 04:09 PM
Re: P0014 Check engine error code
Welcome.
How many miles are on it? Not under warranty I assume?
That code is: 'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
post #3 of 50 (permalink) Old 05-10-2010, 04:17 PM Thread Starter
Well i bought it used did not get any extra warranties when i bought it...It has around 39k probably closer to 40k. It says it is due for a oil change. 2.4L engine I believe..
post #4 of 50 (permalink) Old 05-10-2010, 04:42 PM
Turn signal sticking could be just that someone spilled some drink and it has since dried, gumming up the works. If that's the cause you'll need to clean it somehow. You might be able to find something that'll spray inside the switch. Otherwise you'll have to disassemble it or even replace it.
I wish I could help with your MIL issue. But at least Silver gave you a place to start.
post #5 of 50 (permalink) Old 05-10-2010, 05:01 PM
Like the turn signal won't cancel after a turn or the turn signal stalk switch won't move?
P0014-Exhaust Camshaft Position (CMP) System Performance
This actuator controls the advance or retard of each camshaft, in this case the exhaust. After looking through the diagnostic chart on GM's site I would have to say it would be something for the dealer to handle. It may be covered under powertrain 5yr/100K. There is a couple of bulletins that go with that code that may apply, but that is up to the dealer. I can't post those though, sorry.
post #6 of 50 (permalink) Old 05-10-2010, 05:04 PM
It should be, take it to the dealer.
post #7 of 50 (permalink) Old 05-10-2010, 05:18 PM
Take a look at http://www.chevyhhr.net/forums/showp...&postcount=106. I'd start with an oil change and inspect the filter element for any "debris."
post #8 of 50 (permalink) Old 05-10-2010, 09:15 PM Thread Starter
Ok first things first..Thanks for all the quick replys and the information...Now the turn signal sticks after turning...secondly meaning I bought the car used will the dealers 5yr/100k warranty still cover it?? I thought that was for the original owners only and after you sold it that would be null and void...
post #9 of 50 (permalink) Old 05-11-2010, 04:01 AM
5/100 is a manufacturer's warranty, not the dealer's, so you're good.
post #10 of 50 (permalink) Old 05-11-2010, 04:08 PM
If it is after you make the turn and the wheel is straight, but the signal is still going it is most likely the turn signal stalk switch on the column. Best way to see if it happens is just start the car turn the signal on, turn the wheel a 1/4" turn either way (unless it only does it one way), then turn it back and see if it cancels. There is a plastic piece on the end of the switch that contacts a piece in the column to turn the signals off. Over time the piece wears down or breaks and won't come in contact with the other piece.
check engine light at 20k Marshmellow_Malibu Problems/Service Issues/Troubleshooting (Generation 7) 5 03-04-2010 09:41 AM
'08 silverstone metallic paint code? Silver LTZ General Discussion (Generation 7) 6 12-07-2009 04:18 PM
error code p1441 djlheat General Discussion (Generation 7) 1 06-08-2009 12:08 PM
whats the paint code for.... GTPMALIBU Modifications (Generation 7) 4 06-01-2009 08:41 PM
Check Engine Only on before Start? mithrill Problems/Service Issues/Troubleshooting (Generation 7) 4 04-02-2009 03:17 PM
