High Mounted Stop Lamp Intermittent issue Solved! - Page 2 - Chevy Malibu Forum: Chevrolet Malibu Forums
 7Likes
post #11 of 15 (permalink) Old 10-13-2016, 05:47 AM
Re: High Mounted Stop Lamp Intermittent issue Solved!
I saw several malibu cars here that has the same problem. There should be a recall for this.
jabin is offline
post #12 of 15 (permalink) Old 10-13-2016, 07:34 PM Thread Starter
There is a recall related to that brake light, but have nothing to do with the light. It has something to do with the BCM module. Here is the link to the recall procedure. You might want to try it first.
It is very simple. Also if your cruise control does not work, that indicates the issue is at BCM. I actually had this BCM issue . When that occurred, my cruise control did not work either.
If all the stop lamps do not work, then check the STOP Lamp relay #49 in the fuse box under the hood.
If all that are checked ok, the problem is likely at the lamp. Take your time to try the procedure. The whole day if you need to. It is low risk. but can take time, depending on your skills.
You did not say how much the dealer quoted for the job. But I would bet it is something between $400 - $600. The lamp itself costs about $150. The labor is 2 hours. so it is worth trying..
good luck
08 2LT White/Titanium, 4cyl/4spd
Born 04/08 Lake Orion
hoahai is offline
post #13 of 15 (permalink) Old 10-14-2016, 08:02 AM
Dear JABIN,
As HOAHAI have written, take tour time and everything will be fine.
Be patient ans you will save a lot of money!
The PDF is very well done.
Lessy2009
Chevy for Life
Lessy2009 is offline
post #14 of 15 (permalink) Old 12-01-2016, 12:19 PM
Mine is now Fixed with a toothpick. Thank you Though I just learned that the Service Tech of who misdiagnosed my car, broke the rear dash's plastic behind the metal bar... that was held by a plastic screw... I'll never trust them again.
jabin is offline
post #15 of 15 (permalink) Old 12-01-2016, 01:35 PM
Great post I have the same issue and have had everything out up to the side panels. I was worried about them going back together, but I am going to try this.
Whale is offline
high mounted stop lamp works when cold not when warm sirdeeker Problems/Service Issues/Troubleshooting (Generation 7) 13 02-11-2016 10:13 AM
High mounted brake light failure sirdeeker General Discussion (Generation 7) 15 08-23-2014 05:34 AM
Wiper stop Hang up when on intermittent. lost Problems/Service Issues/Troubleshooting (Generation 7) 3 05-04-2014 09:57 AM
Problum Solved!: High Idle 2000 Malibu LS Cope337 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 01-07-2014 06:51 PM
High Mount Stop Lamp Failure. ElantraMax Problems/Service Issues/Troubleshooting (Generation 7) 6 09-29-2012 05:56 AM
