2008 LTZ Radio Issue - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 6 (permalink) Old 10-10-2011, 06:04 PM Thread Starter
In the last several days my 2008 LTZ's radio began to display the following message: "Aux Input Device." At the same time the radio stops playing. At times it will last for as couple of seconds and several times for like 30 seconds. I have never had any problems with the radio until this issue. I think the last time that I plugged my MP3 player into the aux jack was almost 2 years ago. I listen to the XM radio 100% of the time. Is there a simple fix to this?
gakep is offline
post #2 of 6 (permalink) Old 10-10-2011, 06:54 PM
Re: 2008 LTX Radio Issue
Could be a bad aux-in jack. Anything broken off in there? What happens when you insert an mp3 player plug now?
post #3 of 6 (permalink) Old 10-10-2011, 08:40 PM
Re: 2008 LTZ Radio Issue
Someone else had this same problem a few months ago. Like happens all too often, I don't think they ever reported back with a fix. You might try a search here for AUX and similar.
I believe there is a set of "switching" contacts in the aux. jack. Try plugging something in there a few times. It might clean the contacts.
post #4 of 6 (permalink) Old 10-11-2011, 05:18 AM
I'll confirm that there are switching contacts in the jack. I took the front of my radio off to add another Aux Input jack. Doing so meant altering the wiring a tad. The switching contacts need to be in series, not parallel, but I digress.
If the contacts open the radio may think there's something plugged in.
post #5 of 6 (permalink) Old 10-11-2011, 01:43 PM
I was wondering if it was possible to replace that jack. That's good to know. I imagine it is soldered to the board.
post #6 of 6 (permalink) Old 10-12-2011, 03:06 AM
After rereading my post I may not have been clear.
The stock jack is soldered to the board so it's as permanent as lead can be. It is probably possible to replace it. The most important part is to get one that will properly mate with the fascia. (I sure do like Chrome's spell checker! It just caught fascia misspelled as facia. IE doesn't do that.) To obtain one you might get one bare or you may have to get one in a housing and remove it.
There is a 4-wire ribbon cable that electrically connects it to the motherboard. I had to snip one of those wires to add my external jack. The snip was so I could put the shorting contacts on the new jack in series with the stock one. Before I did that only 1 jack would work correctly since the contacts were in parallel.
'98 Malibu Radio Issue dalejamin Problems/Service Issues/Troubleshooting (Generations 5 & 6) 5 10-13-2010 10:47 AM
2008 Malibu with a radio issue. stevep General Discussion (Generation 7) 0 02-16-2010 06:57 PM
08 Malibu - Issue with Radio Lights hockeyjo General Discussion (Generation 7) 6 12-11-2008 06:36 AM
Malibu 2008 radio wbarr12@comcast.net New Member Introduction 0 09-11-2008 06:53 AM
2008 Malibu LTZ - Homelink 'Issue' 1bird2 General Discussion (Generation 7) 5 04-17-2008 09:45 AM
