p0171 system too lean (bank 1) - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 22 (permalink) Old 04-12-2012, 04:24 PM Thread Starter
Hey Guys, New to the forum, Currently driving a 09 Malibu(102000KM), Had an 05 as well. I am getting this error code on my code reader and know its an O2 sensor. My problem is I dont know where its located, There are 2 on the catalitic converter, One top one bottom. I only thought there were two but when I called the dealership today they told me three, Is there auctually one on the header?
bradman84 is offline
post #2 of 22 (permalink) Old 04-12-2012, 05:15 PM
Re: p0171 system too lean (bank 1)
Engine ? ?
post #3 of 22 (permalink) Old 04-12-2012, 06:01 PM Thread Starter
2.4 L, 6 speed auto transmission.
post #4 of 22 (permalink) Old 04-12-2012, 07:59 PM
The odds that replacing an O2 sensor will fix that 171 are extremely slim. There are many possible causes for an overlean (too much air) condition. How did you verify a faulty O2 sensor?
How many miles?
I would start by cleaning the MAF sensor & throttle body as those are often neglected maintenance chores.
post #5 of 22 (permalink) Old 04-16-2013, 07:04 PM
Did he ever come back with what the resolution was?
mike225 is offline
post #6 of 22 (permalink) Old 04-16-2013, 07:23 PM
Cracked exhaust manifold? Unmetered air leak in the air intake, loose hose clamp at the throttle body or air cleaner? The O2 sensor you're looking for is in the exhaust manifold, firewall side of the engine. I second Greenman's thoughts on throwing an O2 sensor at it unless you've already ruled out a cracked exhaust manifold and unmetered air leaks. You can try cleaning the MAF, doesn't hurt I suppose. I say it's a cracked manifold, even though your car probably has the converter brace already.
post #7 of 22 (permalink) Old 04-17-2013, 01:06 AM
So unitizing the exhaust manifold & the cat wasn't such a great idea? Is there a particular spot that's cracking?
post #8 of 22 (permalink) Old 04-17-2013, 05:00 AM
I wasn't planning on throwing any parts at it today. I'm going to bring it in for maintenance since it's a 2012 with only 59K on it. Just seemed to happen all the sudden in moderate weather.
Mine runs quite rough for several minutes when initially starting and "kinda" smooths out after a few minutes, won't stay running unless you keep the RPMs up.
After reading a lot on it, I'm really sure the dealer is going to throw an O2 sensor at it though I did see one article which was interesting: http://helpforcars.net/obd_codes/p0171_chevrolet.html Different symptoms but strangely the same.
Well, Got to leave in a couple minutes if I want to get there when they open today to scheule my appt.
Thanks for the help,
Mike
mike225 is offline
post #9 of 22 (permalink) Old 04-17-2013, 12:09 PM
Between runners 2 & 3.
post #10 of 22 (permalink) Old 04-17-2013, 01:29 PM
Very good to know. Thanks
DRL System bve32k General Discussion (Generations 5 & 6) 25 05-19-2013 07:13 AM
Need to flush my coolant system, power steering system, and transmission system. HELP kpointer25 Do It Yourself Maintenance (Generations 5 & 6) 4 12-13-2011 10:06 PM
No Fuel Getting To The System Schwiz Problems/Service Issues/Troubleshooting (Generations 5 & 6) 6 08-01-2011 10:25 AM
Hooking Up A PA System icecream1343 Modifications (Generation 7) 6 06-12-2011 11:29 AM
Headrest DVD system maliWHO Modifications (Generation 7) 7 08-27-2009 03:38 AM
