97 Malibu wont start after engine has reached operating temp - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 13 (permalink) Old 06-03-2012, 11:03 AM Thread Starter
Exclamation 97 Malibu wont start after engine has reached operating temp
I was driving my malibu like normal when after about 40 miles. i went to get gas, (i have been using to same gas in it for sometime now). so after i finshed getting gas i went to start it. it cranked up to about 1000 rpm the idled down and died i tryed it again it idled to 400, then it just kept doing that so i stopped so i would flood it. after about 4 minuter it started up and i was able to drive. then the same thing happed yesterday when i went to walmart. then i let the car run for about an hour no problem i shut it off for 10 seconds kick right back on and started i wait a minute nothing. what wrong with my malibu i love this car i dont want to have to get rid of it is my first car and my family has owned it since 2005 184,000 on the dash.
autolite wires
cooper autolite plugs
bad cam sensor (i have the part)
please help me i need my baby to work right
Javien is offline
post #2 of 13 (permalink) Old 06-03-2012, 11:15 AM
Re: 97 Malibu wont start after engine has reached operating temp
I don't know where to start with any real assistance, but I'd like to suggest as kindly as possible that you might find it easier to get folks to read your posts if you'll put a little punctuation in them. The more readers you get the more help you'll get, too.
post #3 of 13 (permalink) Old 06-03-2012, 11:29 AM Thread Starter
i just started it and let it run for 2 minutes and shut it off for 10 seconds wont start up
Javien is offline
post #4 of 13 (permalink) Old 06-03-2012, 11:40 AM
1) You should FIX anything that you know is wrong first (cam sensor).
2) You should NOT just let it sit there and run for an hour.
3) What does "nothing" mean? That the starter wasn't running......or the starter WAS running but it won't fire up ??
I second the request for a little formatting in your posts.
post #5 of 13 (permalink) Old 06-04-2012, 07:30 PM
Two thoughts. Clean the throttle body and check to make sure the fuel pressure regulator isn't leaking. Pull the vacuum hose off and if there's fuel at the hose, the regulator is bad. Clean the throttle body first though, doesn't take long and doesn't cost much.
post #6 of 13 (permalink) Old 07-24-2012, 04:41 AM
Hey, had the same problem with random shut offs after the car warms up. Car would then not start right away, but if I waited (at first 10 minutes, as the problem progressed a few hours) the car would start.
We replaced the ignition control module, and everything was good to go. Problem was that the electrical contacts separated when things heated up, but when the car was cool, everything was fine.
Hope this helps.
Vidurg is offline
post #7 of 13 (permalink) Old 07-24-2012, 10:34 AM
young-gear's Avatar
Exclamation Re: 97 Malibu wont start after engine has reached operating temp
Hope this helps.
You are exactly right! I had the same problem with one of the staffs vehicle, come to find out they did not put the gel on the ICM and it overheated causing the car to shut off randomly. I've dealed with this problem twice in college. Normally people forget to add the gel to keep the ICM from overheating.
3.1l v6 185 hp, CAI
young-gear is offline
post #8 of 13 (permalink) Old 07-24-2012, 10:57 AM
Just a minor point of clarification:
The "gel" or dielectric grease keeps out moisture and other contaminants and prevents the resulting corrosion......which in turn makes heat when the connection starts failing.
IF.....the bad connection and resulting heat is from insufficient contact pressure to start with (and not from moisture or corrosion), the gel can actually make matters worse.
Sometimes that minor point becomes a major consideration.
It can be a factor if/when the offending heat is coming from OUTSIDE the component or connector that is being affected.
post #9 of 13 (permalink) Old 07-24-2012, 11:22 AM
I'm pretty sure 'young-gear' was referring to the metal plate on the bottom side of the ignition module where it sits, in some applictions, directly on a metal bracket for a mounting plate and for some heat dissipation and then the gel or silicone dielectric grease WAS put on the bottom of the module for aiding heat transfer. I think you would actually have seen that back as far as the mid '70's when HEI was relatively new. I think the old 4 and 7 pin modules actually came with that grease and a label telling you to use it for heat dissipation. I'm pretty sure that's the way it was.
post #10 of 13 (permalink) Old 07-24-2012, 12:55 PM
His reference to the pins losing contact led me astray.
That's my story and I'm sticking to it.
I remember using "heat sink compound" on descretely mounted power transistors. I'm not sure it is the same thing as dielectric grease.
99 chevy malibu wont start JMerc628 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 06-29-2014 07:10 AM
2.4 Engine "rattle" at idle and when at operating temp 1LT Problems/Service Issues/Troubleshooting (Generation 7) 10 02-23-2014 11:23 PM
1998 malibu wont start woodworker Problems/Service Issues/Troubleshooting (Generations 5 & 6) 5 04-03-2012 06:16 AM
What is normal operating temp range for 2009 malibu? Cardinal 86 Problems/Service Issues/Troubleshooting (Generation 7) 2 07-06-2011 04:01 PM
03 Malibu Wont start (long) Nephets0 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 1 03-17-2011 09:03 PM
