2001 axle shaft replacement - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 4 (permalink) Old 09-26-2012, 08:35 AM Thread Starter
Alignment shop said the boot on the left side has a tear in it and I should change the entire axel (because the boot repair kits don't work and new axel is not very expensive). OK, I am sure I can handle the replacement myself but I wanted to know from folks that may have done it in the past if I should be aware of any tips or tricks at all.
TIA
Rick
Buckeyert is offline
post #2 of 4 (permalink) Old 09-26-2012, 11:38 AM
Re: 2001 axle shaft replacement
piece of cake catch the fluid use a pry bar and enjoy
gigalomalibuboy is offline
post #3 of 4 (permalink) Old 09-26-2012, 06:57 PM
Not a bad job, pretty straight forward. Sometimes the axles are a bit reluctant to pop out of the trans but keep at it and they come out. You'll find new shafts are actually very reasonable. I think the ones we get are in a Cardone box but who knows if Cardone makes them or reboxes someone elses part.
post #4 of 4 (permalink) Old 11-21-2012, 08:41 AM Thread Starter
Yes, very easy. thank you for the encouragement.
Grease clean up was kind of gross.
One issue, When I popped out the old one no fluid came out.
2001 BCM replacement fcs Problems/Service Issues/Troubleshooting (Generations 5 & 6) 28 10-22-2013 08:28 AM
CV Axle play 07Malibu Problems/Service Issues/Troubleshooting (Generations 5 & 6) 8 09-20-2012 04:44 PM
Axle Nut dagored11 Do It Yourself Maintenance (Generations 5 & 6) 1 05-06-2012 05:24 PM
CV Axle blamb88 Problems/Service Issues/Troubleshooting (Generation 7) 5 04-07-2011 11:00 PM
2001 knock sensor location and replacement ezko84 Do It Yourself Maintenance (Generations 5 & 6) 3 12-07-2010 10:35 AM
