2001 cranking, not starting -- have read up on common causes - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 7 (permalink) Old 11-24-2012, 09:37 PM Thread Starter
Question 2001 cranking, not starting -- have read up on common causes
Hi. Newbie, here. '01 3.1 cranks but won't fire; no sound from fuel pump; theft light goes off after 5 secs with key "on." Was working fine until this happened out of the blue.
I am going to replace the fuel pump relay first. If that fails, I will then have it towed to the dealer because of the possibility of the pass key thing.
I heard that this problem may be beyond the scope of my corner gas station guy. Is going to the the dealer overkill? ($$$)
It is currently in a WalMart parking lot and I can't do too much to it there.
Can I replace the Crank Sensor easily? Where is that and could it help?
Speedy replies are appreciated since this is going to be my tomorrow morning project.
pkguy is offline
post #2 of 7 (permalink) Old 11-24-2012, 10:55 PM
Re: 2001 cranking, not starting -- have read up on common causes
"cranks but won't fire; no sound from fuel pump"
If it's not the relay (which I never had to replace), I'd bet the fuel pump (I was a frequent flyer on fuel pumps until I finally said "Enough is ENOUGH!" and paid for the premium ACDelco replacement ... )
I wouldn't worry about the passkey thing if the theft light goes out after 5 seconds. Until you've eliminated everything else, anyway.
And yes, you could, how easily is a different question. Again, until you get the fuel pump running, I wouldn't worry about that.
post #3 of 7 (permalink) Old 11-25-2012, 07:50 AM Thread Starter
Thanks, Ralph.
I will keep updating until it is resolved.
The corner garage is within pushable range if we do it at night without all the parking lot and street traffic.
pkguy is offline
post #4 of 7 (permalink) Old 11-25-2012, 08:59 AM Thread Starter
As I looked at the relay, there are 5 other one that are identical within that fuse box;
so I swapped the fuel pump one with the AC one and it still didn't start.
The likelyhood of both relays going out is very slim, so looks like a push to the corner garage and then a fuel pump is my Christmas gift to "Bu." (that's what my daughter calls "her" car)
pkguy is offline
post #5 of 7 (permalink) Old 11-25-2012, 01:54 PM
Before just replacing the pump, be sure to check and make sure it's getting voltage.
That's a lot easier with it up on the rack, natch, but it's also worth pointing out that there's other flaws that can cause the pump to not work. Odds are the pump has become an ex-pump - it's pining for the fjords - it's no longer with us - any and all else of that Monty Python skit applies *grins*
post #6 of 7 (permalink) Old 11-25-2012, 03:51 PM
I pine to be in the forest.
I wished upon a star and all I got was sunglasses.
I pinned my hopes on a horse but its ears were too long.
Ain't double entendres great?
post #7 of 7 (permalink) Old 11-26-2012, 07:04 PM Thread Starter
Well, picked up the car from the garage: fuel pump was bad.
Got the Delphi one per Ralph's suggestion: $370 for the part.
+fuel filter and labor = $570
End of saga.
pkguy is offline
Common tools needed for most DIYers? Sunaj Do It Yourself Maintenance (Generations 5 & 6) 7 08-02-2012 10:30 PM
Interesting read about the GM OLM Lgndryhr Off-Topic Discussion 3 06-25-2011 11:58 PM
hello everyone =] please read BeautiBU New Member Introduction 9 04-01-2011 10:11 AM
trouble starting 2001 chevy malibu chevy4life Problems/Service Issues/Troubleshooting (Generations 5 & 6) 4 02-25-2011 09:19 AM
