No Crank/Start - Page 2 - Chevy Malibu Forum: Chevrolet Malibu Forums
post #11 of 14 (permalink) Old 12-12-2012, 08:45 AM
Re: No Crank/Start
By taking the wiring diagram, you can see if the wire TO the starter is getting voltage. After you verify it is, then you can move to the starter and see if the solenoid input is getting voltage. If, however, the ignition switch isn't providing voltage to the starter, then it becomes obvious it must be the switch, right?
OTOH - most folks will replace the switch once or twice before the starter fails.
OTGH - you may want to pull the starter and get it checked at a decent starter/alternator/generator rebuild shop if there's one in your area. We have three or four here where I live, no need to trust AutoZone's tester.
post #12 of 14 (permalink) Old 12-12-2012, 05:12 PM
Re: No Crank/Start
hi ralphp
thx for yr prompt response
got it so we'll test to see if the starter is gettting voltage (if so, this means the ignition switch is good) and it leaves the starter solenoid
can u please which wires i test to do this (also, if u have a link to a wiring diagram ) that would be great
btw - the latest that happened was - kept turning the key to on/off for about 15 minutes and the car started
then i parked it for 10 minutes , and it started right away
then i parked it for 2hours , and it started right away
not sure if this helps us in figuring out what is going on
btw. i only use a regular key for my car (ie no chip in key) its the only key i got with the car a few years ago- does my car have passkey theft system?
db7am is offline
post #13 of 14 (permalink) Old 12-13-2012, 04:41 AM
Re: No Crank/Start
Try this:
With one hand turn the key to Start and hold it, then with the other (and with foot on brake), move shifter to N and wiggle it around a little if it doesn't start up right away.
If that method works your Neutral Safety switch/sensor needs some lookin' at.
post #14 of 14 (permalink) Old 12-13-2012, 02:51 PM
Re: No Crank/Start
hi drivendaily
thx for the info
yeah i put it in neutral and wiggled the shifter side to side and up and down and it didn't make a difference.
here are the symptons again
after turning the key back and forth for 15 minutes the car started
then if i turn the car off and then on again it will start normally
it seems that when the car is warm it starts fine...what could the problem be?
thx
db7am is offline
Intermittent hard crank/no start problem (Not Passlock) Malibu Larry Problems/Service Issues/Troubleshooting (Generations 5 & 6) 22 03-10-2016 01:53 PM
Hard to Crank after Re-Fueling blu99malibu Problems/Service Issues/Troubleshooting (Generations 5 & 6) 0 10-15-2012 05:46 AM
Won't crank, instruments stuck bdmehr01 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 03-18-2011 09:26 PM
2005 LT - Intermittent - Crank OK, but Rough or Difficult Start shecky Problems/Service Issues/Troubleshooting (Generations 5 & 6) 6 12-17-2010 08:28 PM
Crank Sensor Question dalejamin Do It Yourself Maintenance (Generation 7) 0 08-07-2009 11:32 AM
