2004 Malibu blower resistor - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 2 (permalink) Old 12-11-2012, 03:32 PM Thread Starter
I think this issue might have been addressed in a previous post, but I couldn't find any answers that fit my problem specifically.
I have a 2004 Malibu that was in a flood but had a complete electrical work over. Recently when it started getting cold the blower would not work. None of the air settings would work, then it would warm up and they would start working again. I'd taken to unscrewing and rescrewing the little blue box (the resistor?) which was located by the fuses on the passenger side... this worked for a while! There was possibly some kind of corrosion or loose component that would get re-set when I did this... Really, I have no idea. It's started to get really cold out and that little trick had stopped working. Maybe the temperature is not the correct variable, but I do need to get this figured out. Not only do I not have heat, but I do not have defrost, which is a problem in Minnesota.
If possible I would like to fix this myself. What's going on? Is this a part I can pick up somewhere, or would I be better off taking it in? Please help!
Andy is offline
post #2 of 2 (permalink) Old 12-11-2012, 04:22 PM
Re: 2004 Malibu blower resistor
That sounds so much like not all the water was dried after the flood and now it's freezing and keeping the terminals from making contact. (Water expands when it freezes.)
1. Disconnect the battery cables.
2. Remove the connectors at the BCM (body control module)
3. Reinstall/remove about 3-10 times (this cleans the metal contacts)
4. Apply a little (caution! not too much!) dielectric grease
5. Reinstall
6. Attach battery cables
See if this helps. At the very least it'll remove any fretting corrosion present and keep that from being an issue for a very long time.
Blower Motor or Blower Resistor? boilerpilot Problems/Service Issues/Troubleshooting (Generation 7) 3 09-05-2012 11:26 AM
Blower Motor Resistor BMONEY General Discussion (Generations 5 & 6) 10 06-30-2012 10:58 PM
2001 Malibu, blower resistor. FRANKJC Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 03-29-2012 07:40 AM
Broken blower motor or resistor? jester09146 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 8 09-17-2011 07:00 PM
Blower motor resistor Jheuermann Problems/Service Issues/Troubleshooting (Generations 5 & 6) 5 07-18-2010 08:14 PM
