2001 Malibu Hazard Lights - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 18 (permalink) Old 03-12-2009, 11:41 PM Thread Starter
Hey all like the title says I have a 2001 Malibu. So you know the clicking sound your hazard lights/turn signals make when you turn them on right...for a long time now my hazards will just start clicking. They are not on nor do they turn on when the clicking starts. Sometimes it will be a slow click and sometimes its very fast. Does anyone know what might be causing this problem and possibly what to do about it?
skratchmo is offline
post #2 of 18 (permalink) Old 03-13-2009, 11:02 AM
slhaas's Avatar
Re: 2001 Malibu Hazard Lights
Need a new flasher? That is a simple part from a auto parts store. Usually by the fuses in your car.
slhaas is offline
post #3 of 18 (permalink) Old 03-20-2009, 06:54 PM
Malibu Glow's Avatar
slhaas, this is not a typical hazard flasher on the N-body Malibu's. The Hazard switch itself IS the flasher as well. There was a TBS a few years back from GM on the Hazard flasher malfunctioning and GM would replace it free, now I doubt that you can go in and ask for this now but you can try. The cost of the part is around $20.00 but you have to get it through the dealer and not available through any parts store that I know of. I've replaced mine two years ago cause it malfucntioned and haven't had a problem since.
Malibu Glow is offline
post #4 of 18 (permalink) Old 03-23-2009, 03:37 PM
slhaas's Avatar
It is part of the switch? Weird. How do you change it out?
Do you know if the new generation is this way too?
slhaas is offline
post #5 of 18 (permalink) Old 03-24-2009, 09:17 PM
Well for the N-body Malibu's this is how GM did the hazzard and flasher as one part, I don't think they kept it like that on the newer models but the N-body had a recall on it from GM to replace the faulty hazzard switch. Replacing it isn't too bad the whole trim panel that goes around the gauge cluster and reaches over to the passenger side needs to be carefully popped of the dash, there are two screws at the upper portion of the gauge cluster that do need to be removed first though.
post #6 of 18 (permalink) Old 10-31-2009, 02:29 AM
Slide81's Avatar
Send a message via AIM to Slide81 Send a message via Yahoo to Slide81
I'm having a possibly related problem with my 03 Malibu. Turn signals want to work now and then. Such as make a 20 minute drive and they work fine the entire trip. Get back in the car when done and try to drive home and they might blink once or twice and then just stop. Or not blink at all. Usually when it does this I can hit the 4ways switch and it works, but not always. Sometimes it doesn't do anything either. Any thoughts?
Slide81 is offline
post #7 of 18 (permalink) Old 10-31-2009, 05:18 AM
Macleod52's Avatar
If this is the same issue that plagued the Grand Am's/Alero's, it's not your hazard switch, it's the multifunction switch. I believe you may be able to fix it by just putting some dielectric grease on some connectors, but I can't remember. The symptoms are that it sounds like your turn signals come on intermittently.
Take a look here to see if this works.
'09 Malibu LTZ
Ecotec w/A6
Black Granite Metallic
Capitalization & punctuation is the difference between "I helped my uncle, Jack, off a horse." and "I helped my uncle jack off a horse."
Macleod52 is offline
post #8 of 18 (permalink) Old 10-31-2009, 12:37 PM
No Macleod, it's gonna be the hazzard switch on the Malibu, they combined the flasher and the hazzard switch as one part, there is no flasher in any fuse box in the car. There was a TSB on this issue from Chevrolet!!
I had this happen to mine and once I replaced the Hazzard/flasher switch everthing worked fine!
Sponsored by MP Racing.
post #9 of 18 (permalink) Old 10-31-2009, 02:13 PM
Macleod52's Avatar
Well, do the hazzard switch first since it's only $20, but if that doesn't fix it then it's the multifunction switch. It's a common problem on the N-bodies.
'09 Malibu LTZ
Ecotec w/A6
post #10 of 18 (permalink) Old 11-01-2009, 07:40 AM
Hmm, being on three different Malibu sites for the past 5 years (United Malibu's, Malibuclub.ca and MP Racing), I've never heard of any Malibu owner having a problem with their multifunction switch, it has always been the hazzard/flasher switch.
Add OEM fog lights to LS jtblazeltw Modifications (Generation 7) 91 09-18-2012 06:00 AM
Warning – Cut Hazard When Washing OMalibu09 General Discussion (Generation 7) 5 03-14-2009 06:01 PM
need help with a 2001 malibu!! cute_dorkie General Discussion (Generation 7) 1 03-04-2009 12:44 AM
Any way to Program 2001 Malibu FOB myself ? msm15 General Discussion (Generation 7) 1 01-31-2009 09:57 AM
08 Malibu - Issue with Radio Lights hockeyjo General Discussion (Generation 7) 6 12-11-2008 06:36 AM
