i'm ready to give up on 98 malibu - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 19 (permalink) Old 10-03-2010, 08:15 PM Thread Starter
i got a 98 malibu that i can't get running. first off, it's a ................98 malibu LS, 3100 v6. the car would start then die. i found this forum and done some reading. took car to shop, checked all fuses, feul pump, codes, everything was good. found out the auto theft crap was the problem. got the car started and cut the yellow wire and put in a toggle. auto theft light stayed on but the car started and ran great. lasted for about 2 months and then started doing the same crap again. starts and dies. tried flipping the toggle back to normal and going through the turn key to on and wait 10-20 min over and over again. i can't get this car to stay running no matter what i do. i did notice that my daylight running lights do not work anymore when the key is on. i also used a volt meter and checked the 3 wires that connect to the key switch. with the key on, the yellow wire only had 1.3 volts and the white wire only had 3.4 volts.
i would really appreciate any and all help as i'm ready to take this car to the scrap yard.
alyn is offline
post #2 of 19 (permalink) Old 10-03-2010, 08:47 PM
Re: i'm ready to give up on 98 malibu
It sounds like a battery problem. Check the IPC/BFC ACC fuse in the left instrument panel fuse block. The voltage across the junction with the key ON should be 12V or higher. Then, check the Air Conditioning Compressor/Body Function Control Module fuse in the engine compartment fuse block. The voltage across that junction with the key ON should be 12V or higher as well. If they are low, check the voltage across the battery itself.
post #3 of 19 (permalink) Old 10-03-2010, 09:02 PM
Ah, I found the wiring diagrams:
Anti-Theft
Body Computer
post #4 of 19 (permalink) Old 10-04-2010, 04:57 PM
Send a message via MSN to microMXL
password for the diagrams?
microMXL is offline
post #5 of 19 (permalink) Old 10-04-2010, 05:48 PM
Oh, just click on Download. You'd need to sign in/up only if you want to leave a comment.
post #6 of 19 (permalink) Old 10-04-2010, 06:55 PM Thread Starter
thanks, i will give it a try tuesday after work. would a bad battery really make the car start and die.
alyn is offline
post #7 of 19 (permalink) Old 10-04-2010, 07:37 PM
Yep, especially if it's drawing more amperage than the alternator can generate, or if the alternator has crapped out and isn't charging it at all. Below a certain threshold the PCM just won't function.
post #8 of 19 (permalink) Old 10-04-2010, 08:10 PM
The reference voltage has to be 5V or higher (any excess gets bled off by a Zener diode, I think).
BTW, the way I used to check the voltage level at the fuse block was to put the positive probe into the holes on top of the fuse and measure the voltage against the known ground. Come to think of it, I don't even know those mini ATM fuses have holes on top.
post #9 of 19 (permalink) Old 10-05-2010, 04:02 AM
They do, but you have to have what seems like a straight pin for a probe tip!
When I worked in a Ford dealership service department, the PCM would not function below about 10.5 volts (or something near that) even if you could get the starter to crank. I wonder if something similar is happening here?
post #10 of 19 (permalink) Old 10-05-2010, 09:41 AM
Ugh, the wonders of miniaturization. It does sounds like an insufficient voltage is coming from the battery. The starter will crank as long as the solenoid clicks in the full battery voltage/current through the thick battery cable. That other, thin cable from the battery terminal may be the cause of the voltage drop.
iPhone Ready Radio Chad General Discussion (Generation 7) 13 10-26-2011 09:41 PM
Anyone give their Malibu growl? Mufflers? Deathlok Modifications (Generation 7) 0 08-23-2009 10:18 PM
Give this pickup truck the gold mattman8 Off-Topic Discussion 3 08-14-2008 03:45 AM
