2003 malibu NO gas/temp gauge, or radio and heat or a/c - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 3 (permalink) Old 01-26-2011, 04:50 PM Thread Starter
I recently had the computer changed in my car, wouldnt start because of anti theft system. Recently the fuel gauge temp gauge as well as radio and heat/ac do not work. i checked all fuses and they where all good, for a time being i would jiggle the ignition switch and they would brefly turn on but next time i would start the car nothing worked again, and now nothing works even when i jiggle the key, also tried beating the living hell out of dashboard but all i got was a sore hand, anyone have any suggestions!!!
Browniebpp24 is offline
post #2 of 3 (permalink) Old 01-26-2011, 05:29 PM
Re: 2003 malibu NO gas/temp gauge, or radio and heat or a/c
Well you say you have a 2003, but post this in the 2008-Up section?
MOVING....
post #3 of 3 (permalink) Old 01-26-2011, 07:41 PM
Welcome to the forum. I think you're on the right track, suspecting the ignition switch. The ignition switch in that generation Malibu had a lot of current flowing through it and would eventually develop bad/intermittent contacts. If you were to take it out, you might even see blackened terminals on the back.
2004 Malibu starting and temp gauge issues csv86 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 12-26-2011 12:22 PM
2001 Malibu: AC/Radio/Fuel Gauge/Gas Gauge all out jathaller Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 08-29-2010 04:00 PM
Temp Gauge Issue JamesKelly Do It Yourself Maintenance (Generation 7) 1 06-02-2009 12:14 PM
calibrate temp gauge Skrappi Do It Yourself Maintenance (Generation 7) 5 04-07-2009 08:00 PM
Temp gauge doesn't quite reach the middle... SAABturboGuy Problems/Service Issues/Troubleshooting (Generation 7) 12 01-22-2009 10:28 PM
