01 malibu fuel and temp gauge inop - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 7 (permalink) Old 08-07-2011, 11:29 AM Thread Starter
Hi i have a 01 malibu 3.1l
The fuel and temp gauge is not working
the car was running fine both gauges worked and suddenly the fuel and temp gauge dropped . i heard a pop noise when it happened . the car runs ok otherwise.
I read that the pcm might be bad so i replaced it with another one and it still has the same propblem
I replaced lower manifold gasket on it . after that i started no notice the fan wouldnt come on ,found blown fuse ,replaced it and replaced fan relays .
I noticed that the fan was making growling noise when it worked so i replaced it as well. now this happened.
HELP Please .
Thank you
sobstylp is offline
post #2 of 7 (permalink) Old 08-09-2011, 05:22 PM
Re: 01 malibu fuel and temp gauge inop
Any lights on in the dash? Are the gauge needles in the sweep of the gauge or are they, in the case of the fuel gauge below E even though you have plenty of fuel? Sometimes if you disconnect the battery, when you reconnect it, the cluster sees a voltage spike and will drive the needles out of their normal sweep. The easiest fix is to pull out the cluster and kind of shake the cluster to work the needles around to where they're supposed to be. Some guys use a paper clip and through the trip reset button get the needle back to the proper place. Get back to us and tell us where the gauge needles are pointing and if you have any tell tale lights on in the instrument cluster.
post #3 of 7 (permalink) Old 04-30-2015, 07:46 PM
My daughter has an '01 w/ the same problem. For the past few years about every six months the temperature gauge would suddenly drop to less than zero (another words it looked like no power was applied - flat-lined). If I recall the check engine light came on and it pointed to the temp sensor. It was replaced and the problem came back.
Since then each time this happened, we would reset the code w/ a OBDII device. The temp gauge goes back to working for many months and one day it drops out again. We repeat the procedure to read w/ ODBII and clear errors.
Today the same error occurred AND the gas gauge is also not reading. Reading and clearing w/ the ODBII rectifies neither of these conditions.
Any advice?
alanb is offline
post #4 of 7 (permalink) Old 05-01-2015, 12:17 AM
Any advice?
alanb is offline
post #5 of 7 (permalink) Old 05-04-2015, 09:28 AM
Any advice?
This problem is complicated, my friend experienced and he sold his car
hajilulung is offline
post #6 of 7 (permalink) Old 05-06-2015, 07:45 PM
Speed_Freak5150's Avatar
What are the codes?
10 Malibu 1LT
'14 Traverse 1LT
Speed_Freak5150 is offline
post #7 of 7 (permalink) Old 05-08-2015, 03:36 AM
P0128 was the code. If I recall this was for the thermostat. It has been replaced.
The error code did clear. Started the car and the temperature and gas gauge are still zero.
Turned the engine off. Rechecked the OBDII and there are no error codes, but these two gauges still not working.
What changed this time is: 1) the gas gauge is also not indicating anything and 2) resetting error w/ the OBDII does not fix the temperature (or gas) gauge.
If anyone has the schematics for this section, I can follow them.
Thanks in advance.
alanb is offline
2004 Malibu starting and temp gauge issues csv86 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 12-26-2011 11:22 AM
2003 malibu NO gas/temp gauge, or radio and heat or a/c Browniebpp24 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 01-26-2011 06:41 PM
Fuel and temp gauges, a/c inop on start aimee Problems/Service Issues/Troubleshooting (Generations 5 & 6) 1 08-31-2010 09:44 AM
2001 Malibu: AC/Radio/Fuel Gauge/Gas Gauge all out jathaller Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 08-29-2010 03:00 PM
02 Malibu - Fuel gauge going down too quickly Philthy42 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 02-28-2010 08:25 AM
