I have a 2007 Malibu that has an Intermittent airbag light/message that only seems to pop up when the cabin is warm, ie windows rolled up in the sun. Once the car cools off it will clear itself. Tech 2 shows a B0089 code, which has a description of "supplemental restraint deployment loop #2 short to battery" or similar. Information floating around the Internet is minimal, anyone have a diagnostic flow chart or items to check?
Some of the newer generation vehicles had issues with the connectors under the passenger seat, or the harness tugged too much when the seat was at one end or the other. There have also been reports of the passenger seat sensor/switch indicating a passenger when one was not present. It may be as simple as disconnecting and reconnecting the plug a few times to see if the issue goes away, or it could be more involved than that.
