98 Malibu 3.1V6 Stalls immediatly after starting - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 8 (permalink) Old 11-28-2011, 01:54 PM Thread Starter
I have a 98 Malibu with 3.1 The car dies right after starting. It will restart then die immediately. This was common until last night when I got it into the garage and was able to rev it up by giving it some gas. Would stay running about 3K rpm but would die immediatly after getting out of the gas. So I dont believe it is a security issue. I scanned it and got these codes back
P0300, P0101, P0108, P0121, and P0101 again.
I am going to do a fuel pressure check but I have suspision that pump is ok.
It primes on start and turns off like it has built pressure will check to make sure. Car ran fine until one cold morn i woke up to start headed inside and it died. then always died right after restarting. Any help would be great
Car has approx 140K
I have tried the reseting of the security by leaving on on for 10 min then to off position and back to on for 10min back to off then started no difference. same thing just stalls out immediately.
The light never went off even for 15-20 mins.
ANY HELP WOULD BE GREAT
Is this a fuel pump problem I just want to make sure before changing.
What should fuel pressure read before starting and after running?
Thanks
Chris
bingchris93 is offline
post #2 of 8 (permalink) Old 11-28-2011, 02:30 PM Thread Starter
Re: 98 Malibu 3.1V6 Stalls immediatly after starting
I just got done checking fuel pressure at the fuel rail. On initial prime dial reads 40 psi but then starts dropping (cheap fuel pressure test kit?) then after it starts the pressure goes to 35 psi and then goes back to 40 psi after it stalls. Hope this helps.
What should the psi be on initial prime and after running I was thinking around 55psi
Anybody know thanks again
post #3 of 8 (permalink) Old 11-28-2011, 09:08 PM
52-59 PSI according to the service manual - see the page at http://www.philent.biz/images/2000_M...sure_Range.PDF
(Note: My web server. Use normal precautions when accessing.)
post #4 of 8 (permalink) Old 11-29-2011, 11:36 AM Thread Starter
After rechecking the pressure I came up with 42psi at the fuel rail.
After researching some more I found that correct pressure readings should be 41-47 psi. Is this Correct anyone?
After removing the codes from the computer with my scanner the car started and has been running fine.
Can anyone tell me why this is and what maybe the problem was?
I am assuming the pump is not bad now....?????
post #5 of 8 (permalink) Old 11-29-2011, 06:07 PM
snip
The FACTORY SERVICE MANUAL PAGE I linked to specifies 52-59 psi.
What other research did you do?
No, 41-47 is NOT correct. It's close, but there's a chance the motor may run lean due to insufficient fuel at critical junctures (like when you pull out in front of that fully loaded dump truck ... )
Pump may still be failing.
post #6 of 8 (permalink) Old 11-29-2011, 07:14 PM Thread Starter
snip
The info you provided was published after the car was produced and it states that:
All 2000 model year 3.1 L and 3.4 L engines have a revised fuel pressure regulator and Multec II fuel injectors.
The fuel system operating pressure is 358-405 kPa (52-59 psi) on these applications.
Notice all 2000 (I have a 1998) and it also states that they went with a new fuel injection system on some level after 99.
snip
Thanks again
post #7 of 8 (permalink) Old 11-29-2011, 07:57 PM
I double-checked, and you're right, for 1998 it says 41-47 PSI.
My mistake.
snip
post #8 of 8 (permalink) Old 11-30-2011, 03:16 AM
Exclamation Re: 98 Malibu 3.1V6 Stalls immediatly after starting
Originally Posted by RalphP View Post
snip
snip
snip
snip
OK, both of you guys need to step back a little. Enough with the insults!
RalphP, your response was the first volley and was inappropriate. bingchris93, your comments just served to escalate. Both of you need to exercise a more mature level of conduct on this forum.
You're both getting a 3-day vacation to think about it.
And you'll notice that your comments have been edited. I don't get paid for this, and I am NOT your parents.
2009 Malibu Starts then Stalls manofice Problems/Service Issues/Troubleshooting (Generation 7) 18 09-05-2013 09:45 AM
2001 Chevy Malibu Starts and Stalls Themaincomputer Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 08-24-2011 11:09 AM
when put in drive the engine stalls 08 malibu mikesf808 Problems/Service Issues/Troubleshooting (Generation 7) 2 06-09-2010 05:48 AM
