2011 LTZ I-Pod hook up - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 9 (permalink) Old 10-17-2012, 10:50 AM Thread Starter
Just wondering if there is a way to remove the Ipod hook up from the radio face to inside the dash? I'm tired of the cable always hanging from my radio. I was trying to see if someone has already done this. I am going to attempt but wanted to try and grab some input first. My plan of attack is going to be popping the dash open, and trying to unclip the plug, and then use the factory rubber plug to close up the hole, then just hook the cable up and tape it inside the dash.
Brooklyns Finest is offline
post #2 of 9 (permalink) Old 10-17-2012, 11:52 AM
gmitch2LT's Avatar
Re: 2011 LTZ I-Pod hook up
Instead of moving the jack, try a flash drive with your music on it. You can find them extremely small so they dont stick out very much at all. Depending on how many GB you want, you can find them under 20 bucks.
2012 2LT
Summit White
Titainum/Leather-Suede
17' Polished Aluminum
15% tint
OEM Spoiler
Bright White Vinyl Emblem Overlay
gmitch2LT is offline
post #3 of 9 (permalink) Old 10-17-2012, 05:23 PM
Ay-yup! Shore is small!
Too bad the USB in the radio is upside down. Don't stick out much, either...
post #4 of 9 (permalink) Old 11-05-2012, 05:57 AM Thread Starter
Nice!! Good call on the flash drive. Gotta check that out. Does doing this allow you to still set up Playlists and such like you can do on I tunes?
post #5 of 9 (permalink) Old 11-05-2012, 04:01 PM
Only if the radio does, or if you store them in such a fashion on the drive. It's just a flash drive, nuttin' more.
post #6 of 9 (permalink) Old 11-05-2012, 06:19 PM Thread Starter
Awesome!! Thankyou.
Frank
post #7 of 9 (permalink) Old 11-15-2012, 01:54 AM
tremain.roseman's Avatar
You could go to your Local Chevy Dealer and price out the Personal Audio Link (PAL). It basically allows you to store your IPOD in your glove box, and it would charge your IPOD as long as it was not the 5 Volt charging IPOD that requires additional power (most new IPODS have a 12 V charging system) It was a extra option with our LTZ's, however I am not sure if the dealer can add it after the fact. Worth a shot if you ask me. I might do it, if they can't figure out why my USB port keeps kicking my IPOD off the head unit.
2012 Malibu LTZ (LZ1) Born December 2011
Black Granite (Yup its a 2.4L)
Received: April 28 2012 (after one long year in Afghanistan)
Mods: JL Stealth Box, 8000k HID for Lows and 6000K Fogs, 20% Tinted Windows
Upcoming Mods: Plasti Dipped Wheels and Chevy Emblem
Old Car: 2009 Chevy Malibu LT Aka: Highway Trooper 67,000 Miles
tremain.roseman is offline
post #8 of 9 (permalink) Old 11-18-2012, 08:12 AM
you can do like i did and remove the radio for the dash and solder onto the back of the USB connection and run a remote line to the center console.
ID:	2532   Click image for larger version
Johndoe0336 is offline
post #9 of 9 (permalink) Old 11-19-2012, 03:30 PM Thread Starter
@Johndoe that is awesome. I couldn't get the flashdrive to work this seems like the best solution. You don't have and pictures or a write up on the process do you?
How can i hook these subs up? Kevinmuff Modifications (Generations 5 & 6) 1 06-10-2012 05:25 PM
How to hook up a GPS without using the power jack thilehoffer Modifications (Generation 7) 7 07-06-2011 02:57 AM
what wire to hook up load eq in front turn kyleer Modifications (Generation 7) 2 05-05-2011 05:13 PM
Ipod hook up? Graham18ce Modifications (Generation 7) 0 12-02-2008 06:46 AM
iPod hook up to factory head unit Malibulove08 Modifications (Generation 7) 10 11-14-2008 07:15 AM
