3.6L Performance Chip - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 37 (permalink) Old 05-28-2008, 10:01 AM Thread Starter
2008LTZcrazy's Avatar
I have recently talked to the service advisor at the dealership where I purchased my car and a service tech at the local Cadillac dealership. They both claim that the V-6 in the LTZ is the same as the CTS. The difference is the CTS has 304hp while the LTZ only has 252hp which according to them is simply a difference in the programming of the on-board computer and a different air intake. This can be changed by installing a K&N cold air intake and a performance chip. Has anyone seen a company carry any perfomance parts for the new Malibu yet?
2008 Malibu LTZ
Dark Grey Metallic
Special order interior: Cocoa / Cashmere
Limo-Tinted all around
All available options
LOADED...
2008LTZcrazy is offline
post #2 of 37 (permalink) Old 05-28-2008, 10:17 AM
mpoczobut's Avatar
Post Re: 3.6L Performance Chip
I believe your service department is mistaken. Yes the Malibu 3.6 has the same engine as the CTS but it is 263 HP base model. The 304 HP engine is the Direct Injection upgrade which I believe is more than programming and intake (it is a completely different engine). I have heard as well that the difference of 11 HP in the base CTS vs. Malibu is simply programming.
2008 Chevrolet Malibu LTZ - Red Jewel
Sunroof / Rear Power Package / V6
Manufactured 03/08 in Fairfax
mpoczobut is offline
post #3 of 37 (permalink) Old 05-28-2008, 10:19 AM Thread Starter
Same engine different intake.
2008 Malibu LTZ
Dark Grey Metallic
LOADED...
post #4 of 37 (permalink) Old 05-28-2008, 10:31 AM
mpoczobut's Avatar
It may be the same "engine" but there is a lot more involved then a different intake...
http://media.gm.com/eur/cad/en/news/...erformance.doc
Direct-Injection technology
The 3.6L Direct Injection engine is the premium engine option for the 2008 CTS. This technology on the 3.6L VVT engine contributes greatly to a 15-percent increase in horsepower; 8-percent increase in torque, and 3-percent improvement in fuel consumption. Additionally, the application of direct injection reduces cold-start hydrocarbon emissions by 25 percent and it is designed to operate with regular unleaded gasoline. The engine also helps the CTS achieve zero to 100 km/h performance of 6.3 seconds and a top speed of 249 km/h (electronically limited).
Gasoline direct injection differs from the fuel delivery process of a conventional fuel injected engine by delivering fuel directly into the combustion chamber, where it is mixed with air drawn in the chamber; the conventional design mixes the air and fuel prior to delivery into the combustion chamber. The advantage is improved fuel control and a more complete burn, which generally requires less fuel than a conventionally injected engine of the same size and configuration.
With the 3.6L direct injection engine, fuel is introduced directly to the cylinder during the intake stroke. As the piston approaches top-dead center, the mixture is ignited by the spark plug. The fuel injectors are located beneath the intake ports, as the intake ports only transfer air. Direct injection also permits a slightly higher compression ratio than if the fuel were delivered with conventional fuel injection. The result is better fuel consumption at part and full throttle. The engine uses conventional spark plugs similar to other high-feature V-6 engines.
A high-pressure, returnless fuel system is employed. It features a high-strength stainless steel fuel line that feeds a variable-pressure fuel rail. Direct injection requires higher fuel pressure than conventional fuel injected engines and an engine-driven high-pressure fuel pump is used to supply up to 1,740 psi (120 bar) of pressure. The system regulates lower fuel pressure at idle – approximately 508 psi (35 bar) and higher pressure at wide-open throttle. The exhaust cam-driven high-pressure pump works in conjunction with a conventional fuel tank-mounted supply pump.
Direct injection’s fuel delivery enables very efficient combustion to help reduce emissions, particularly on cold starts – the time when most tailpipe emissions are typically created. Also, direct injection permits a higher compression ratio – 11.3:1 in the case of the 3.6L – which has a positive influence on fuel economy.
3.6L Direct Injection VVT
The 3.6L Direct Injection VVT engine is based on a sophisticated 60-degree dual overhead cam (DOHC) V-6 design. It is the latest member of a growing family of V-6 engines developed for applications around the world, drawing on the best practices and creative expertise of technical experts in Australia, Germany, North America and Sweden.
Features found on the 3.6-liter VVT DI include:
• Aluminum engine block and cylinder heads
• Dual overhead cams with four valves per cylinder and silent chain primary drive
• High-pressure, engine-driven fuel pump
• Advanced multi-outlet fuel injectors developed to withstand high pressure and heat
• Stainless steel, variable pressure fuel rail
• Four-cam phasing (VVT – see description below)
• 11.3:1 compression ratio
• Aluminum pistons with floating wrist pins and oil squirters
• Polymer coated piston skirts
• Forged steel crankshaft
• Sinter-forged connecting rods
• Structural cast-aluminum oil pan with steel baffles
• Electronic throttle control with integrated cruise control
• Coil-on-plug ignition
• Advanced direct injection capable engine control module (ECM)
• Optimized exhaust manifolds with close-coupled catalytic converters
• Fully isolated composite camshaft covers
• Outstanding noise, vibration and harshness control
• Maximum durability with minimum maintenance
• Common manufacturing practices for efficiency and exceptional quality
Four-cam phasing
The 3.6L Direct Injection VVT employs four-cam phasing to change the timing of valve operation as operating conditions such as rpm and engine load vary. The result is linear delivery of torque, with near-peak levels over a broad rpm range, and high specific output (maximum horsepower per liter of displacement) without sacrificing overall engine response and driveability. When combined, direct injection and cam phasing technologies result in an unmatched combination of power, efficiency and low emissions in gasoline V-6 engines.
Cam phasing pays big dividends in reducing exhaust emissions by optimizing exhaust valve overlap and eliminating the need for a separate exhaust gas recirculation (EGR) system.
By closing the exhaust valves late at appropriate times, the cam phasers allow the engine to draw the desired amount of exhaust gas back into the combustion chamber, reducing unburned hydrocarbon emissions. The return of exhaust gases also decreases peak temperatures, which contributes to the reduction of oxides of nitrogen (NOx) emissions. In tandem with the dramatic 25-percent reduction in cold-start hydrocarbon emissions brought on by direct injection, the 3.6L Direct Injection VVT V-6 surpasses all emissions mandates, and does so without complex, weight-increasing emissions control systems such as EGR and air injection reaction (AIR).
post #5 of 37 (permalink) Old 05-28-2008, 01:25 PM Thread Starter
Interesting. Very informative website you quoted. Thanks for the clarification. Maybe the dealerships need to be informed a little more on their products. It would be nice to get over 300hp out of the car though.
2008 Malibu LTZ
Dark Grey Metallic
LOADED...
post #6 of 37 (permalink) Old 05-28-2008, 01:34 PM
mpoczobut's Avatar
No problem! 300hp and better fuel mileage sounds good to me too! But with everything there comes a cost... It does look promising though as one way for GM to get closer to meeting the CAFE regulations and not compromise performance.
post #7 of 37 (permalink) Old 05-28-2008, 01:38 PM Thread Starter
What do you think about this?
http://cgi.ebay.com/ebaymotors/REAL-...spagenameZWDVW
2008 Malibu LTZ
Dark Grey Metallic
LOADED...
post #8 of 37 (permalink) Old 05-28-2008, 01:43 PM
mpoczobut's Avatar
As said by another member in another thread; I too am skeptical about these inexpensive performance/fuel efficient modifications. If it were that cheap and that easy, the likes of GM wouldn't need to spend Billions of $$s to figure out how to get their entire fleet at 30MPG or better by 2015.
If you buy one and truly see the benefit please let us know, we'd love to hear the results!
post #9 of 37 (permalink) Old 05-28-2008, 01:56 PM Thread Starter
I am skeptical about the controller and how it creates better fuel economy. I am interested in the horsepower gain though. Just wondering what the general though was on these things. They work on trucks for power.
2008 Malibu LTZ
Dark Grey Metallic
LOADED...
post #10 of 37 (permalink) Old 05-28-2008, 09:38 PM
DrD
This looks like the inline resistor part that was discussed on our other thread. If it is, the so-called "Chip" is just a simple resistor (a 5’ part) that tricks the air sensor into thinking the temperature is offset so the computer tries to compensate by offsetting your fuel/air ratio. The offset might give a minor fuel savings under some conditions, but likely could cause more problems under altering conditions that are more common. Looks to be just another "Too good to be true story".
A true "Chip" modification requires that you replace an actual memory IC or processor IC deep in the computer board assembly. Some vehicle systems will let you reprogram the "Chip" without a physical hardware change if you happen to have access to the special reprogramming tool, the special GM access codes, and new software code from an expert performance hacker.
DrD
DrD is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Chip that adds 60+ Hp and 20mpg on new malibu Arty General Discussion (Generation 7) 11 04-24-2008 05:36 AM
