TPMS question (again I know) - Page 2 - Chevy Malibu Forum: Chevrolet Malibu Forums
post #11 of 13 (permalink) Old 02-11-2013, 10:34 PM
Speed_Freak5150's Avatar
Re: TPMS question (again I know)
The TPMS light will be on. Some states will fail an inspection for having TPMS lights on.
10 Malibu 1LT
'14 Traverse 1LT
Speed_Freak5150 is offline
post #12 of 13 (permalink) Old 02-14-2013, 08:56 PM
BillD64's Avatar
Originally Posted by morando6784 View Post
what happens if you don run the senors? Is there just a pressure light on? Im getting a set of 20s and there already mounted and ready, so would it be ok if i just waited till i got around to pulling my sensors off my stocks and mount them later, it will just have that light on till i get them put on correct. Theres not some crazy setup to were it wont let me drive it is there, you never with these new vehicals.
A tire shop can break down the tires and move the sensors although it is usually better to go with new ones in the new wheels. All they do is push the tire bead down, reach in, grab the old sensor, and remove it. Then they push the bead down on the new wheel/tire combo and put the sensor in.
Almost as easy as changing a standard valve stem. No need to rebalance the wheel since they don't move the tire.
Bill
BillD64 is offline
post #13 of 13 (permalink) Old 02-19-2013, 12:22 AM
Bill
I would recommend getting the wheels rebalanced because of the weight difference of the sensors.
10 Malibu 1LT
'14 Traverse 1LT
Gear in this thread - Powered by O'Reilly Auto Parts
TPMS, Center Caps and Tire question Dilatory Wheels, Tires & Suspension (Generation 7) 6 01-19-2013 08:42 AM
TPMS Question gmitch2LT Problems/Service Issues/Troubleshooting (Generation 7) 17 10-15-2012 08:40 AM
TPMS question twiztedtrav Wheels, Tires & Suspension (Generation 7) 8 08-02-2010 08:26 AM
Question for folks who have done a reset of the TPMS Speedster Do It Yourself Maintenance (Generation 7) 7 08-06-2009 12:30 AM
Question about winter tires with TPMS Yury General Discussion (Generation 7) 12 12-03-2008 06:45 PM
