Is that possible to install in Malibu 2005 radio from new Malibu or other cars? - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 22 (permalink) Old 08-19-2009, 09:19 AM Thread Starter
Is that possible to install in Malibu 2005 radio from new Malibu or other cars let say Equinox... or Impala?
Malibu MAXX LS 2005
252000 km.
ectar is offline
post #2 of 22 (permalink) Old 08-19-2009, 10:05 AM
cavalier2000's Avatar
Re: Is that possible to install in Malibu 2005 radio from new Malibu or other cars?
see if they look the same and go from there...i have a blazer radio in my cavy...but only cause it was free.
also you will probably have to take it to the dealer to get the theft relearn on the radio
cavalier2000 is offline
post #3 of 22 (permalink) Old 08-19-2009, 10:11 AM
Think this might cover your situation....and even with the scan tool....read: dealer....you still might be out of luck.
Regarding 2004 radios, the Theftlock theft deterrent system is a feature on all base and uplevel radios. There is no need to program a security code into the radio as in past model years. The theft deterrent system now utilizes class 2 serial data to determine if the radio is in the appropriate vehicle. Each time the radio receives the "run" power mode message, it compares the VIN information it has stored to the VIN information received from a module on the class 2 serial data circuit responsible for transmitting that information. If a mis-match occurs, the radio display will indicate to the user the radio is locked. Once this takes place, a DTC will set, the radio will not respond to any button presses and become inoperative. The 2 scenarios able to cause this condition are:
A radio is installed from another vehicle.
A module which communicates on the class 2 serial data circuit which supplies VIN information to the radio is replaced and not properly setup with the correct VIN information for that vehicle.
The only way to unlock the radio is by using a scan tool.
douglas92000 is offline
post #4 of 22 (permalink) Old 08-19-2009, 10:12 AM
yup have to use a tec 2...
post #5 of 22 (permalink) Old 08-23-2009, 08:21 PM Thread Starter
Looks like it is impossible I've compared pictures (found on ebay) of radios: Malibu 05 and Malibu 08 , Enquinox 07 have different connectors at the back. I guess they are not compatible. Size wise they are apparently similar (mounts are similar)
I will continue my research, but with less energy
Malibu MAXX LS 2005
252000 km.
ectar is offline
post #6 of 22 (permalink) Old 09-13-2009, 08:49 AM
Yeah why not. I think you can easily upgrade.take it to the dealor, he will do that.
Samwilson66
samwilson66 is offline
post #7 of 22 (permalink) Old 09-13-2009, 10:03 AM
Malibu Glow's Avatar
It's not possible to swap in a radio from a newer car, the wiring and connectors are different. Just take a look at aftermarket stereo system adapters to see the differences between the years on GM cars and trucks and you'l find GM didn't stay with the same style of connection on the radios.
Sponsored by MP Racing.
Malibu Glow is offline
post #8 of 22 (permalink) Old 01-19-2010, 10:19 PM
Ive got an 05 malibu (new body) and i am replacing the stereo with another 05 stereo, this will require me to take it to the dealer to change the vin, correct?
goldencupkake is offline
post #9 of 22 (permalink) Old 02-28-2010, 10:06 AM
Not sure but it might have to deal with the theft system that would probably need to be re-programmed with the new radio.
post #10 of 22 (permalink) Old 09-28-2010, 12:41 AM
I was wondering the SAME thing. I'd like to know if any other these will fit in my 2005 new style Malibu LS with no ONStar or XW or CD changer...
I would love to have this one http://www.mnrelectronics.com/20poamcdwiau.html But any of these would do as well, if they'd fit and WORK PROPERLY...
http://oem-auto-accessory.com/257828...x_mp3_cd6.html
http://oem-auto-accessory.com/259807...brand_new.html
http://oem-auto-accessory.com/258650...brand_new.html
Let me know what ya'll think! And thanx in advance xD
btfldezastr is offline
Aftermarket radio install loomdog32 Modifications (Generation 7) 5 01-30-2012 07:57 PM
Amplifier install - 98 Malibu chrisgeo_2000 Modifications (Generation 7) 0 08-07-2009 09:15 PM
2005 Malibu Radio Dropkick General Discussion (Generation 7) 1 06-02-2009 08:44 AM
STRONG CARS the Malibu! malibustrength! Malibu Ride Showoff (Generation 7) 8 12-30-2008 08:02 PM
purchasing a 2005 Malibu tn_sands_rep Buying and Leasing (Generation 7) 5 10-30-2008 07:52 PM
