Aftermarket Powered Subwoofer - Page 2 - Chevy Malibu Forum: Chevrolet Malibu Forums
post #11 of 19 (permalink) Old 01-31-2013, 08:53 PM
humblebeast07's Avatar
Re: Aftermarket Powered Subwoofer
ok...i dont need a line converter. the amp i showed already has high line inputs(aka no need for converters..witch have been known to be shitty for sub setups) All I need is to run my 4 gauge power wire through the firewall, find a 12v signal (acc, remote from stereo...something that powers up with the car) And tap into the rear speakers....if they are bi amped(i didnt notice when i looked) i will tie into the low side and set my amp on full....no problem
2013 Malibu 2LZ Blk on Blk
5%Tint/Debadged
humblebeast07 is offline
post #12 of 19 (permalink) Old 02-01-2013, 01:03 AM
nutcrunch's Avatar
Originally Posted by jow26ny View Post
The rear speakers are BI AMPED! so you need bi wiring... 2 positive terminals. ALSO THE MALIBU HARNESS will not work. Its the chrysler 300 harness.. call your dealer and they will tell you
We are talking about 2013 malibus here. It might be the same as your 2009 or it might not be. Are you sure you are talking about the 2013?
2015 Impala 2LT
V6 305hp/264tq
Conv PKG
Adv Safety PKG
Sunroof
50/35 Suntek CXP tint
RIP
2013 Malibu ECO 1SA PCN pkg
May 2012-Aug 2015
nutcrunch is offline
post #13 of 19 (permalink) Old 02-01-2013, 01:18 AM
SeaRay245se's Avatar
The Jensen amp I will be putting in also has the high inputs so no need for converters here either and from what i have found out the rears are not BI AMPED on the pioneers like they were on the old Bose systems.
2015 Ram 2500 Laramie
Power Wagon
Crew Cab W/Leather Int.
2013 Chevy Malibu 2LT
Crystal Red Tint
Leather and Pioneer
2013 Chevy Malibu 3LT
Atlantis Blue Met.
2.0 Turbo and Pioneer
2007 Harley Ultra Classic
1986 Ford Mustang
460/c6 caged and tied
2015 255 Tracer Air
1968 14' Duoboat
SeaRay245se is offline
post #14 of 19 (permalink) Old 02-02-2013, 05:03 PM
It looks like the easiest way to run the power wire is up into the plastic piece under the hood then across to the passenger side, drill through the fire wall the under the trim and carpet to the back....If anyone has any input let me know
5%Tint/Debadged
post #15 of 19 (permalink) Old 02-04-2013, 03:24 PM
Pretty much that's what I did for the power wire and tapped in for remote in fuse box.
ID:	2727   Click image for larger version
Power Wagon
Crystal Red Tint
Leather and Pioneer
Atlantis Blue Met.
1986 Ford Mustang
2015 255 Tracer Air
1968 14' Duoboat
post #16 of 19 (permalink) Old 02-04-2013, 09:56 PM
Can you take a picture of where you ran the power wire through the fire wall and also from under the dash? And did you just wire into the radio in the fuse box
5%Tint/Debadged
post #17 of 19 (permalink) Old 02-05-2013, 01:54 AM
Sure but not for a bit car is back in Virginia and won't be back till end of this month now.I'll be going up there in a couple weeks but not sure if I'll have time to do it then but will when it gets back here.....For the remote I tapped into the fuse that controls the power output plugs.On the 13 there switched with the key so it makes it perfect for it.
Power Wagon
Crystal Red Tint
Leather and Pioneer
Atlantis Blue Met.
1986 Ford Mustang
2015 255 Tracer Air
1968 14' Duoboat
post #18 of 19 (permalink) Old 02-05-2013, 06:09 AM
so did you go threw the dash on the passenger side?
5%Tint/Debadged
post #19 of 19 (permalink) Old 03-12-2013, 07:06 PM
I am trying to install a Bazooka Tube in the trunk of my 2013 1LT. I only have speakers in the door to slice into. Where is the best location to splice into the speaker wires?
rw01513 is offline
Will aftermarket subwoofer/amp work with stock stereo? MalibuFred Modifications (Generation 7) 19 09-15-2012 06:35 PM
Problem Mounting my powered flat sub... mb54 Modifications (Generation 7) 1 09-22-2011 06:06 PM
WTB: silver ice metallic passengerr side powered mirror slhaas Trading Post (See rules before posting an item for sale!) 2 02-13-2010 10:00 PM
subwoofer time GTPMALIBU Modifications (Generation 7) 0 12-10-2008 10:00 PM
