Changing DRL from headlamps to amber fog lights (Tur signal lights) - Chevy Malibu Forum: Chevrolet Malibu Forums
post #1 of 2 (permalink) Old 06-30-2016, 11:03 AM Thread Starter
bigdrowe's Avatar
I am fairly new to the forum, but did do a search, and found no info. Does anyone know how to change the DLR from the head lamps to the amber fog lights. I do not have lower fog lights, but though about putting the LED strips along the chrome trim in the bumper.
How would I do either of these? Could I do both? Amber and lower fogs?
Thank you
bigdrowe is offline
post #2 of 2 (permalink) Old 06-30-2016, 01:46 PM
SCompRacer's Avatar
re: Changing DRL from headlamps to amber fog lights (Tur signal lights)
The issue you run into with DRL and Halogen headlights, the low beam is the DRL using PWM (pulse width modulation) or reduced voltage from the BCM (body control module). When the light sensor on the dash detects darkness, PWM ceases and the low beam gets full B+ voltage from the BCM.
I don't know for sure, but you might run into an amperage issue through the BCM if you connected your fog lights to the low beam. Your fog lights would have DRL PWM voltage until dark, then full brightness. IIRC, the LED strip around the fog light connects to its own power source and is triggered by the DRL. I don't know if the DRL signal is enough to trip the relay.
Check for fog light DRL posts. I plan to add LED fog light housings in the future. My car came with the fog lights.
2015 Malibu LTZ Silver Ice Metallic
"Make yourself necessary to somebody." Ralph Waldo Emerson
SCompRacer is offline
lights on after changing hub averypb114 ChevyMalibuForum AutoGuide Support / Help 1 05-15-2016 07:34 PM
How to keep fog lights on like city lights? sk8almost44 Modifications (Generations 5 & 6) 30 09-22-2011 07:23 AM
make it so your fog lights stay on when turn brite lights on kyleer Modifications (Generation 7) 5 06-05-2011 03:53 PM
Amber LED Warning Lights tomx20 Trading Post (See rules before posting an item for sale!) 4 05-16-2011 03:48 PM
Fog lights & hid lights TheBu! General Discussion (Generations 5 & 6) 2 12-26-2010 09:14 PM
