Official HID Lighting Thread - Page 30 - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 11-27-2012, 05:54 PM   #291
mysilversurfer 12
2012 Malibu 1lt
silver ice metalic
mysilversurfer 12's Avatar
Default Re: Official HID Lighting Thread
i have read many of these posts and seen that just adding the relay harness can or does brighten the headlights,is this true or am i just not understanding something?
mysilversurfer 12 is offline   Reply With Quote
Old 11-28-2012, 03:10 AM   #292
DrivenDaily
Administrator
2011 3.6/ A6 LTZ
Red Jewel Tintcoat
DrivenDaily's Avatar
Gallery: 6
Garage
What it does is instead of using the extremely small wires to power the lights they are now used to energize a relay that then uses larger wires directly from the battery (through a fuse!) to power the lights. This reduces the losses due to resistance to a very small level. When a device draws a lot of current (amperage, amps) over a wire with greater resistance something has to give and that's usually the voltage, or, to keep the voltage where it belongs the amps will be limited. Overall it results in less power available to the device and causes the wiring to heat up more.
Imagine trying to put out a fire with a garden hose when a fire hose was available. Which would you choose? Voltage is like water pressure and amperage is like water flow (gallons per second). So with larger wires there's more electricity available to operate the device and less is converted through resistance to heat the wiring. More pressure (volts) and more flow (amps) results in the device operating more like the specs say it should.
'11 LTZ, born Aug 2010, Fairfax, KS
V6/A6, Red Jewel Tintcoat / Cocoa-Cashmere, Sunroof
Cool Mods: Drop-in K&N air filter; 20% tint, DRLs on turn signals,
Painted grilles, 1-wipe washer, WeatherTech mats, CHMSL Pulser
How-to: LEDs in mirrors :: How-to: 1-Wipe Wash
How-to: Remote express windows up/down
Traded: '09 2LT Black Granite Metallic V6 / A6 at 20,058 miles
Muffler mod on '09
DrivenDaily is offline   Reply With Quote
Old 11-28-2012, 07:24 PM   #293
mysilversurfer 12
2012 Malibu 1lt
silver ice metalic
thank you, that makes sense,i think ill try just the hid harness and see what happens,i appreciate your detail.
Last edited by mysilversurfer 12; 11-28-2012 at 07:34 PM. Reason: forgot to add something
Old 11-28-2012, 07:36 PM   #294
mysilversurfer 12
2012 Malibu 1lt
silver ice metalic
would i just use a normal hid relay harness for the h11 ?
Old 11-28-2012, 08:29 PM   #295
DrivenDaily
Administrator
2011 3.6/ A6 LTZ
Red Jewel Tintcoat
Gallery: 6
Garage
I believe the answer to that is, Yes.
Muffler mod on '09
Old 11-30-2012, 12:53 PM   #296
ariker01
There are a fuse and a relay in the under-hood fuse box that control the DRLs. Pull one or both and they'll turn off. If they don't then maybe someone has modified your car or there is an issue elsewhere.
Thanks for the suggestion. I ended up replacing my my harness and ballasts with a much better quality. I have sense had no problems with power inconsistency or flickering. I just keep my parking lights on during the day and turn on the HIDs' at night.
AutoLoc ION HID's 6K
Upgraded Euro Ballasts
ariker01 is offline   Reply With Quote
Old 02-11-2013, 01:10 PM   #297
TG2013BU
2013 Malibu LS
Black Granite
TG2013BU's Avatar
do u know where i can purchase a HID Kit for 2013 Malibu LS?
TG2013BU is offline   Reply With Quote
Old 03-22-2013, 06:17 PM   #298
kpkacts238
2010 Malibu LS
Black
Thank you this was very helpful
kpkacts238 is offline   Reply With Quote
Old 04-06-2013, 07:31 AM   #299
rcgreen85
2009 Malibu 1LT
black
Has anyone seen these... CMF EDIT: url removed from 1st post by new member - Chinese wholesale link I hope its true and they're starting to catch on that we want upgrades for our headlights. If it is I believe the 2012 is still gen 7. Not sure on the price tho. It appears to be that a group purchase is required but not positive on that, just curious if anyone else has run across these.
rcgreen85 is offline   Reply With Quote
Old 04-08-2013, 02:49 PM   #300
rcgreen85
2009 Malibu 1LT
black
So to start I'm not sure how beneficial this will be with installing HID but possibly with changing the low beam bulbs regardless of the application...
I recently took the car up to the dealership to get some work done along with changing the bulbs. After all the work was completed I noticed some chips from when they installed the bumper so I took it back up there. While the tech who worked on my car took the bumper off ect another tech claimed he changes the lows by only popping the inner fenders. Has anyone else been able to accomplish this? Ive searched the forums but haven't seen anyone else claiming this talent lol. If it can be done I would imagine it'd be to difficult to install the ballast/relays.
The tech that was claiming he could do this was a pretty big guy so I'm thinking he may be a little confused on his abilities.
Replacing the interior lighting of the malibu aliitp Modifications (Generation 7) 60 09-01-2011 08:13 PM
Gauge Lighting Question???? LiLPhenom03 General Discussion (Generation 7) 17 04-04-2010 09:54 AM
Accent Lighting? samesun General Discussion (Generation 7) 0 09-12-2009 02:04 PM
1st official TSB/recall notice byeuboy Problems/Service Issues/Troubleshooting (Generation 7) 3 07-17-2008 08:06 PM
