The check engine light comes and goes. fault code P0010 is the only one showing up on the scanner. So I changed the camshaft position sensor with a part from Advance Auto. The light continued to come and go so I put an AC Delco part in there 213-1690 thinking I had a bad one from Advance. The light is still coming on.
I checked the CMP actuator solenoid connector & measured the resistance across the two pins. It reads 12.8ohms. Is that good?
What should I be checking next?
'08 malibe with 2.4l.
Thanks!
Thanks!
