Related or unrelated not sure...
Passenger side power lock does not work at all. Drivers side works intermittently. FOB and switches on both doors will unlock all other doors so I do not believe it is switch or keyless related. I have checked fuses.. all good. Not sure of next step...
Factory remote starter also quit working around same time. Is it possible if the door is not locking automatically that an incorrect signal is being sent to the BCM to allow the car to remote start? I mean as far as the BCM is concerned there is an unlocked door which prevents the car from starting...
Prefer not to go to dealer... is there a common relay or something I might need to check? Both doors with the same problem seems like there may be a common point to the issue...
