The AC/Radio/Fuel Gauge/Gas Gauge does not work when the car is running or when the ignition is in the "on" position. The radio does work when it is in the "acc" position.
Prior to this problem the cruise control was not working and I was tinkering with the button. The next time I started it up is when I lost the Gauges/Raido/AC. So, I think it is connected.
I took it to the dealer and they also said I had a bad BCM in addition to problems with both the radio and the cruise control, but they acted uncertain, so I didnt let them do anything for that reason (in addition to wanting $1300).
Here is the kicker, after I refused to let them do the work, they installed the ignition back in the car and a kid pulled the car around for me and everything worked fine when I got in and drove away.
Everything worked fine for several weeks until my wife was driving the car and , forgetting that it was broken, hit the cruise control. Nothing happened immediately, but next time she started the car all four things were not working again. Thanks for any help or suggestions.
I did install a new ignition switch and it changed nothing.
