Replacing inner tie-rod ends 2001 Malibu - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 06-21-2012, 09:50 PM   #1
applianceguy
2001 Malibu LS
Silver
Default Replacing inner tie-rod ends 2001 Malibu
How hard would it be for the DIYer and what is the best place to get a good price for a decent pair of these.., I am not looking for high dollar ones, I am using the made in China complete struts in the front and those are good.
Please let me know the best toute.., whether to DIY or take it to the shop.
Thanks
applianceguy is offline   Reply With Quote
Old 06-22-2012, 04:55 PM   #2
Rodents
ASE Certified Technician
2011 Malibu 2LT
Default Re: Replacing inner tie-rod ends 2001 Malibu
I'll stick with the 'how hard to do' end of this as I wouldn't use off brand parts. Probably Moog only but I'm sure some other members can point you in the right direction there. There's a pair of flats on the inboard end of the inner tie rod, that is what you unscrew the rod with. There's a tool to do it, an example of what is looks like and what you'll spend for it is here
Amazon Amazon
. You'd need a half inch drive breaker bar, a torque wrench if you're so inclined when you put it together, you would also need to get the bellows kits or some way to retain the bellows to the rack when you go back together since the bellows boot comes off to access the flats on the inner tie rod. Loosen the lock nut on the tie rod, pop the outer tie rod out and unthread it from the inner tie rod. Count the number of turns you come out as it's a ball park gauge to where you need to be going back together. Change the tie rod, there's usually a drop or two of red thread locker put on the threads where they screw into the rack. Put it back together in the reverse order. 74 ft.lbs. is the torque spec for the inner tie rod to the rack. You should get an alignment done as toe will be off. Check the rack end seals for leakage. If they're leaking replace the rack.
Rodents is online now   Reply With Quote
Old 06-22-2012, 08:11 PM   #3
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Moog, ACDelco, Raybestos Professional Grade (NOT SERVICE GRADE!!!) - that's all I would bother with going back on. Don't bother with the Moog bellows, though - I went through two sets (!!) on my Cougar inside of a year, got ACDelco on there now (THOSE seem to be lasting much better.)
http://www.rockauto.com/catalog/rafr...&parttype=7428 has several you can choose from.
The tool can be bought at Harbor Freight, http://www.harborfreight.com/inner-t...set-96558.html . Note: Rodents would chew one of those up in a month or so on the rack, but for a DIY, it's a bit more affordable. Or, of course, there's the Loan-A-Tool type programs most of the regional/national parts houses have.
RwP
Old 02-25-2013, 12:05 PM   #4
applianceguy
2001 Malibu LS
Silver
Rodents,
Thanks for the help. I still haven't done it yet, but I think I will go with Ralphs suggestion of going to Harbor freight.
Ralph,
Sorry to hear you got rid of your Malibu. I recently went to the JY and got me a replacement glove box.
Old 02-26-2013, 06:06 PM   #5
Rodents
2011 Malibu 2LT
Some stuff at Harbor Freight is okay, I've got some stuff from there and it is what it is for the price. Did you try a parts place, Advance, AutoZone. I think some of them rent or loan tools unless I'm dreaming that up. It's most likely a tool you'll use once and maybe never again.
Old 02-26-2013, 10:41 PM   #6
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
They do, Rodents. I did mention that also
But with *counts* back down to three R&P vehicles in the family, I figured it was well worth having the tool for us.
RwP
Old 02-27-2013, 04:37 AM   #7
applianceguy
2001 Malibu LS
Silver
Right on.., you are both right, it is about having the right tool for the joob, and saving MONEY!!!
That is why I went with these..,
http://rover.ebay.com/rover/0/e11400...OC%3AUS%3A3160
I will rent the tool from Auto zone, and install the when they arrive.
I hope I do not need seals for the steering rack/pinion.
I figured that all the rest of the front end is Primechoice brand stuff, and I have had that on there for a year and a half with no problems, so might as well continue the cheap, made in China theme with the front end parts.
The reality of it all, is nothing lasts forever anyway, (Ralph can attest to that) so might as well do it on the Cheap! Besides, after putting all this money into the front end, the tranny could go, or some A hole w/out insurance could hit me, and then I would really be screwed!
Thanks for your help guys!
Old 02-27-2013, 08:40 AM   #8
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
My problem with that, personally, is that ... there's only one of me. A tie rod comes apart while driving (has happened to me!), and there's a good chance there's no more of me after the car runs sideways into a brick divider (luckily I was going slow over a rail road track, and could pull off to the right like the right tire was pointing ... )
Nothing wrong with shopping around, but I insist on good quality parts for my car's front end.
That's my choice, anyway.
RwP
You may not post new threads
You may not post replies
Replacing outer tie rod on 2000 Malibu LDollar Problems/Service Issues/Troubleshooting (Generations 5 & 6) 4 01-26-2012 06:11 PM
Replacing the interior lighting of the malibu aliitp Modifications (Generation 7) 60 09-01-2011 08:13 PM
2001 Malibu Overheating even after replacing everything. Please help crushmark80 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 9 12-21-2010 05:58 PM
need some help with my 2001 malibu!! cute_dorkie Problems/Service Issues/Troubleshooting (Generations 5 & 6) 2 06-08-2010 09:38 AM
Audi R8 test drive ends crashing in a river trev0006 Other Rides 0 08-21-2008 01:36 AM
