camshaft position sensor - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 07-22-2012, 10:39 AM   #1
scally32536
2009 Malibu LT
white
Question camshaft position sensor
2009 Malibu, 4 cyc. Check light reported P0010 malf. Replaced sensor still have problem. Is there 2 cam shaft senors on this engine, and if so where might it be located on engine. Thanks
scally32536 is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 11:41 AM   #2
greenman
ASE Certified Technician
Default Re: camshaft position sensor
You replaced the wrong part as have many others before you. I assume it's Autozone that is giving out that bad/confusing information.
There are two long threads on the p0010 code on a 2.4l already:
http://www.chevymalibuforum.com/foru...ighlight=p0010
If you have questions after reading those feel free to ask here.
Old 07-22-2012, 11:53 AM   #3
MalibuKen
Banned
2011 Malibu 1LT+
White
Originally Posted by scally32536 View Post
2009 Malibu,
Unless you have more than 100,000 miles on this car, it should still be covered by the 5/100 powertrain warranty.
Why are you messing with it yourself if a dealer will fix it at no cost to you ???
Old 07-22-2012, 12:02 PM   #4
greenman
Good point. Covered under the powertrain.
Old 07-22-2012, 01:38 PM   #5
rluck9277
CMF Senior Member
2013 Malibu LS
Summit White
rluck9277's Avatar
You will be ok if you still under the bumper to bumper warranty. But it isn't covered under the powertrain warranty. I had the same code, it is the sensor that controls the VVT function of the camshafts. There are two, one for the intake cam, and one for the exhaust cam. They are located under the engine cover on top of the camshaft cover on the left side of the engine. There are 2 right next to each other.
Anyways when I had my code I took it to a dealer expecting it to be covered under the powertrain warranty (I was well over 36,000 at the time) and it wasn't. They wanted to charge me something like $260 to install it. The sensor was only $55, so I bought it and installed it my self. It was very simple, and took me like 15 minutes to install it.
From what I gathered from the dealership, the powertrain warranty only covers the mechanical aspects of the engine and transmissions, electrical sensors are not covered.
Life begins at 140MPH...just wish I could get there!
rluck9277 is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 02:50 PM   #6
greenman
I believe you are confusing the CMP sensors with the CMP actuators. That confusion leads to replacing the wrong part as was the OP's case. Several people in this forum have reported that they have had the actuators covered under the powertrain warranty. It is the actuators (sometimes the circuit) that commonly fail. The 10 code is for the intake actuator (or the actuator circuit).
Old 07-22-2012, 03:17 PM   #7
MalibuKen
Banned
2011 Malibu 1LT+
White
There are all kinds of "gotcha"s in car warrantys but if a part is required for the engine to run......or for the transmission to make it move.....that IS the powertrain and it should be covered. I don't think I would have accepted that story without some further checking and/or complaining.
My dealer provided a "gap" powertrain warranty, that takes it to 8 years/100K miles. There is one glaring exclusion: it doesn't cover gaskets or seals......or damage resulting from that failure. What a crock.
Also it says several places that a covered part must "break".
I'm suspecting that this "warranty" might not even be worth what I paid for it.......which is nothing.
Old 07-22-2012, 05:52 PM   #8
rluck9277
CMF Senior Member
2013 Malibu LS
Summit White
rluck9277's Avatar
Yeah, I meant the actuator. My dealership and I may not have been on the same page when I asked him about it. I should see if I still I have the reciept for the part and see if they will cover it. Probably not since I installed it, but it might be worth a check.
2009 Mailibu - 2.4L - Check Engine - Intake Camshaft Position Sensor coopdog Problems/Service Issues/Troubleshooting (Generation 7) 8 08-12-2014 04:43 PM
Bad throttle position sensor jds54 Problems/Service Issues/Troubleshooting (Generation 7) 17 07-11-2014 10:42 AM
P0010 light still on after camshaft position sensor change 2001FZ1 Problems/Service Issues/Troubleshooting (Generation 7) 65 10-21-2013 07:46 PM
INTAKE Camshaft Sensor Kels Problems/Service Issues/Troubleshooting (Generation 7) 8 01-06-2012 08:28 AM
Crankshaft Position Sensor & Relearn dalejamin Do It Yourself Maintenance (Generation 7) 0 08-05-2009 07:58 AM
