Where's the radiator drain plug? - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 08-02-2012, 05:41 PM   #1
aScionsEnd
2000 Malibu LS
green
aScionsEnd's Avatar
Default Where's the radiator drain plug?
I know it sounds like the simplest of questions, but I can't seem to find it. I have a coolant leak and for now I'm just flushing the system and using a sealant to buy me some time until I can get the actual problem addressed, but I can't seem to figure out how to drain the coolant out, I have a 2000. Any help is appreciated.
aScionsEnd is offline   Reply With Quote Quick reply to this message
Old 08-02-2012, 09:42 PM   #2
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Default Re: Where's the radiator drain plug?
Not all radiators have one.
You can remove the lower radiator hose.
BTW - the sealant? Can easily make your small problem a bigger one.
Where does it leak?
RwP
Old 08-02-2012, 10:57 PM   #3
aScionsEnd
2000 Malibu LS
green
aScionsEnd's Avatar
Where does it leak?
RwP
Lower Intake Manifold Gasket, big surprise huh? I've pretty much been learning everything about cars myself for the past 3 months, and just taking things as I come and doing the best I can to research to fix whatever needs to be done. Basically I'm saying I don't know much about cars, I'm broke, and this is my first car. So again, any suggestions are appreciated.
Old 08-03-2012, 03:22 AM   #4
2ndchancemalibu
CMF Junior Member
1999 Malibu
The radiator drain plug on my 99 is on the drivers side towards the bottom. It's a white nylon plug and the end of a 1/4 inch extension is used to loosen it. But like RalphP said, it is much better to just pull the bottom radiator hose off to avoid stripping the nylon plug. Changing the lower intake gaskets isn't a hard job, just involved. Make sure you have access to a good set of metric tools and a inch pound and foot pound torque wrench. Make sure you get a book to help guide you through the process like a haynes.
2ndchancemalibu is offline   Reply With Quote Quick reply to this message
Old 08-03-2012, 10:11 AM   #5
Rodents
ASE Certified Technician
2011 Malibu 2LT
Be careful using a 'mechanic in a can'. While they do sometimes work, they can also cause you headaches down the road. GM dealers sell coolant sealant tablets that you crush and put in the system. In a system like yours, you would add them at the radiator hose and not where the cap is. I don't know if anyone in the aftermarket carries the tablets. The tablets seemed to work fairly well and the long term side effects were more easily cleaned out if necessary. Best bet is replacing the gasket as soon as financially possible.
Radiator Drain 2009 MC1 Do It Yourself Maintenance (Generation 7) 13 02-23-2015 08:23 AM
2011 Malibu Making sure its the Oil Pan/Drain Plug greg4malibu Do It Yourself Maintenance (Generation 7) 15 07-16-2011 03:25 PM
2005 malibu v6 radiator drain cock access exuL1B47 Do It Yourself Maintenance (Generations 5 & 6) 0 12-04-2009 11:48 AM
radiator drain cock zpilot Do It Yourself Maintenance (Generation 7) 1 08-09-2009 07:00 PM
Drain Plug size? ElantraMax Do It Yourself Maintenance (Generation 7) 0 05-17-2009 02:09 PM
