Lower Control Arm replacement: replace bushing? - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 10-11-2012, 06:31 AM   #1
SomeCallMeTim
2009 Malibu LT
Midnight Blue
Default Lower Control Arm replacement: replace bushing?
Hi Folks!
New to the forum here.
I've got a loose right ball-joint and I've purchased a Moog replacement lower control arm/BJ with a zerk (hopefully gets a longer life than the sealed BJs). Should I replace the lower control arm bushings with some Moog LCA bushings for compatibility? Or is using the existing LCA bushings good enough?
Thanks!
SomeCallMeTim is offline   Reply With Quote Quick reply to this message
Old 10-11-2012, 06:53 AM   #2
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Default Re: Lower Control Arm replacement: replace bushing?
Without seeing the bushings, it's hard to say remotely.
!I! would due to the labor involved. But that's me.
The rear one looks like it's expensive, but not as big a pain to replace as the front one is - so if nothing else, do the front one and leave the rear one for later.
RwP
Old 10-11-2012, 07:59 AM   #3
SomeCallMeTim
2009 Malibu LT
Midnight Blue
Thanks for the reply Ralph.
I forgot to mention that this is for the front right LCA. The moog LCA that I bought has the BJ pressed into the LCA, the front bushing in place, but does NOT come with the rear bushing.
My question is more along the lines of: can I just use the LCA rear bushing that is already on the car? Any chance of the new Moog LCA not being compatible with the original bushing?
Thanks!
Old 10-11-2012, 08:19 AM   #4
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Yah, that does make a difference :grins:
It's supposed to just fit, so I'd say yes.
OTOH, now would be a good time for JustIn Case (boy, I HATE that guy! He tends to cost me so much money!)
RwP
Old 10-11-2012, 08:32 AM   #5
Speed_Freak5150
2010 Malibu 1LT
Imperial Blue
Gallery: 2
If it were my car I would go ahead and replace it since you are already there. Save yourself some time and money. replacing now means you only have to get the car aligned this time. replace it later and all of the parts have to come off again and that means another trip to the alignment shop.
10 Malibu 1LT
'14 Traverse 1LT
Speed_Freak5150 is offline   Reply With Quote Quick reply to this message
Old 10-11-2012, 08:55 AM   #6
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Two things - 1) There's no adjustment per se on the LCA on these cars, it may not need an alignment afterwards. 2) No, not all the parts have to come off - the rear LCA bushing bolts to the LCA, so it's very possible to replace it without removing the LCA ..I THINK. Haven't tried, maybe not, but it's worth remembering.
RwP
Old 10-11-2012, 01:08 PM   #7
chevyguy8893
2009 Malibu LTZ
Silver Ice
chevyguy8893's Avatar
+1, GM doesn't even recommend an alignment after replacing the lower control arm. It can only go in one way without adjustment. You can have it checked, but it will probably be within the factory spec. Unless the bushing is torn up or dry rotted, I wouldn't even bother with replacing it. Even if you had to replace it later removing the lower control arm is extremely easy to do.
The first time I did it I took about a half hour, many many malibus later I was down to around 10 minutes to swap them out on the 4 cylinder. It is a little more time consuming with the V6 since the engine mount has to be loose on the side you are working on to jack the engine up and remove the bolts for the control arm. Even then it is still not hard to do.
4 cyl w/6 speed auto
Silver Ice Metallic paint
-20% tint
Old 10-11-2012, 05:50 PM   #8
SomeCallMeTim
2009 Malibu LT
Midnight Blue
chevyguy-
Thanks for the response and the encouraging words... I have never swapped out an entire LCA (only pressed out/in BJs).
Two quick questions:
1. After removing the rear bushing bolt, does the bushing just slide off the LCA spindle? Or do I have to get a little rough with it?
2. Do you have to jack-up the LCA @ the BJ to get the BJ tip back into the knuckle?
Thanks so much!
Old 10-11-2012, 07:57 PM   #9
chevyguy8893
2009 Malibu LTZ
Silver Ice
Originally Posted by SomeCallMeTim View Post
chevyguy-
Thanks so much!
I will first start off with a warning before doing this, watch where your hands are.
Moving on, there may be a little bit of a fight, but it won't be much. I generally encountered them just coming out. To make this easier remove the nut and bolt holding the ball joint stud to the steering knuckle. Use a pry bar through the opening in the control arm to the bottom of the engine cradle to pop it out of the knuckle. Then, get the knuckle out of the way while you are still prying. Without it being in the hole there will make the rest of the job much easier.
Getting the ball joint stud back into the knuckle doesn't require a jack. Pry the new control arm down and align the knuckle with the stud. Then, slowly let up on the control arm making sure it stays lined up. Once it is close you can grab ahold of the brake disc and move the suspension whichever way needed to get the ball joint in place. It will just fall into place, which is why I mentioned watching where your hands are. You may have to move the ball joint up or down a little to get the bolt to line up with the indent in the ball joint.
Sorry, I seem to have an inability to provide a quick answer today .
-20% tint
Insurance
Year
Malibu
Trim Level
LS, 1LT, 2LT or LTZ
Color
Labor to Replace Right Lower Control Arm/Ball Joint coopdog Wheels, Tires & Suspension (Generation 7) 1 04-25-2012 03:17 PM
Lower control arm replacement paulk68 Do It Yourself Maintenance (Generations 5 & 6) 9 01-16-2012 03:43 PM
Lower control arm leaking fluid MILO Problems/Service Issues/Troubleshooting (Generation 7) 3 01-31-2011 02:39 PM
Dealer suggested to replace both control arms... but I dont believe him ectar Problems/Service Issues/Troubleshooting (Generations 5 & 6) 3 06-05-2010 06:44 PM
Can I replace control arm myself in my townhome garage/driveway? ectar Do It Yourself Maintenance (Generations 5 & 6) 15 04-23-2010 08:28 AM
