How-to: Fix codes P0010, P0011, P0013 or P0014 on the 2.4L ecotec engine: - Chevy Malibu Forum: Chevrolet Malibu Forums
Old 11-11-2012, 09:52 PM   #1
greenman
ASE Certified Technician
Default How-to: Fix codes P0010, P0011, P0013 or P0014 on the 2.4L ecotec engine:
Remove the engine cover. Find the two small cylinders just to the left of the #1 spark plug. They are called the intake & exhaust camshaft position (CMP) actuator solenoids. I recommend that you replace them both. But if you choose, you can just replace the intake actuator for a 10 or 11 code or the exhaust actuator for a 13 or 14 code. There are no aftermarket versions available...just the OEM ACDelco. Either get from a dealer or (probably cheaper) online (though a bit harder to find online than at a dealer). Just remove the hold-down bolts & pull up on the actuators. Put engine oil on the new o-rings & don't over-torque the hold-down bolts (torque spec is only 7 ft-lbs). The actuators are keyed differently (& have different part numbers) so you can't interchange them.
Part #
Intake: 12646783
Exhaust: 12646784
http://www.chevymalibuforum.com/foru...1&d=1352699374
Click image for larger version
Name:	intake&exhaust cmp actuators.jpg
Old 04-10-2013, 04:16 PM   #2
GBPackerFan
CMF Junior Member
2009 Malibu LTZ
Light Blue
Default Re: How-to: Fix codes P0010, P0011, P0013 or P0014 on the 2.4L ecotec engine:
I see in this post that it says no Aftermarket replacements available...granted this was posted about 6 months ago, but I did buy an aftermarket Exhaust Camshaft Solenoid from Oreilly's yesterday and installed it. CEL just went off today...we will see how reliable/durable it is. Just an FYI, there are some becoming available.
The one I bought was $44.
GBPackerFan is offline   Reply With Quote Quick reply to this message
Old 05-25-2013, 03:17 PM   #3
BOBD1950
2009 Malibu 2LT
BLACK
Question Re: How-to: Fix codes P0010, P0011, P0013 or P0014 on the 2.4L ecotec engine:
Part #
Intake: 12646783
Exhaust: 12646784
@ 68k still a warranty ticket>?
Have an extended 6/120
BOBD1950 is offline   Reply With Quote Quick reply to this message
Old 07-09-2014, 05:35 AM   #4
PEACEKEEPER
I got a p0023/p0014 code on my 09 malibu. Changed the exhaust solenoid and reset light. Went to store and light came back on!!! What's my next to do to fix this!!!
PEACEKEEPER is offline   Reply With Quote Quick reply to this message
Old 07-10-2014, 11:34 AM   #5
GBPackerFan
CMF Junior Member
2009 Malibu LTZ
Light Blue
Are your connectors in good shape to your Solenoids? Also, are you low on oil? What viscocity do you use? Has it been changed recently? All these factors could make this code pop up, especially if you changed the solenoid....report back and we can help you from there.
2009 Malibu LTZ, 2.4L, grocery hauler, 107k (wife's car), no mods because it's a 2.4L Malibu
2001 Mustang GT, 4.6L, 5SPD, bolt ons, suspension, 162k and running strong (My car)
Old 07-10-2014, 12:58 PM   #6
Project84
CMF Senior Member
2009 Saturn Aura XR 2.4L
Project84's Avatar
Furthermore - when I unplugged mine to replace them, one connector was saturated pretty well with engine oil, believe it was the intake one - closest to the front bumper. I used electrical contact cleaner spray to clean it all out and let it air dry about 5 minutes before I plugged it back into the new sensor.
Yours might be wet w/ oil and not making good connection or giving faulty reading.
Good luck!
Project84 is offline   Reply With Quote Quick reply to this message
Old 08-31-2014, 06:14 AM   #7
sirdeeker
2009 Malibu 2LT
Blue
Part #
Intake: 12646783
Exhaust: 12646784
This is a great post. For those like me who are afraid of breaking plastic parts I thought I would add some details about removing the engine cover. The cover is held to the throttle body by a band clamp. The screw is accessed from the driver side of the vehicle. On my 09, the engine cover has a slot which allows you to see the screw head that is used to adjust the clamp. Using the slot for viewing makes this 100% easier.
Once that clamp is loosened, there is a hose on the front passenger side that can easily be removed. Then pull up on the rear cover. Each side is just pushed onto a rubber grommet. Once the back is loose, pull up around the throttle body in the front. It may take some gentle rocking but if the clamp is loose it will wiggle free.
sirdeeker is offline   Reply With Quote Quick reply to this message
Old 09-07-2014, 11:48 AM   #8
ConsGTA
2010 Malibu 1LT
Silver
ConsGTA's Avatar
I had P0013 (Exhaust Camshaft Position Actuator Solenoid Control Circuit) come up after finishing a 5 hour drive about a year ago. Basically I cleared the code, drove back to Toronto with no problems. Code hasnt come back and I've put about 10,000km more on it. The only other work I've done after on the car is changing the plugs.
ConsGTA is offline   Reply With Quote Quick reply to this message
Old 10-17-2014, 01:41 PM   #9
AlfistoSteve
2009 Malibu LTZ
Emerald Red
Part #
Intake: 12646783 ss by 12615873
Exhaust: 12646784 ss by 12655421
Just had this same problem on our 2009 Malibu.
I changed exhaust cam solenoid now to see if check engine light (CEL) (MIL) stays out after I reset it.
Point of information 12646784 number has now been superceded by 12655421
Point of information 12646783 number has now been superceded by 12615873
Solenoid valve was listed for 56.14 but with my discount I got it for $45.46 at Chevy dealer.
OReilly's had it listed for 49.99 under Dorman 917-216 number but did not have it in stock. Amazon lists Dorman valve for $24.75 on sale.
AlfistoSteve is offline   Reply With Quote Quick reply to this message
P0014 Check engine error code xdirtydogx Problems/Service Issues/Troubleshooting (Generation 7) 47 01-07-2015 08:26 AM
P0010 Service Code Hotrodjrd Problems/Service Issues/Troubleshooting (Generation 7) 48 10-08-2014 09:05 PM
2009 Malibu 2.4l code P0013 3pt1lumina Problems/Service Issues/Troubleshooting (Generation 7) 3 08-04-2014 01:40 PM
P0010 Intake Actuator ElantraMax Problems/Service Issues/Troubleshooting (Generation 7) 5 11-02-2012 12:30 PM
the notorious p0010 dtc roxy paige Problems/Service Issues/Troubleshooting (Generation 7) 2 09-16-2011 11:13 PM
