How do you install a new coolant reservoir? - Chevy Malibu Forum: Chevrolet Malibu Forums
» Auto Insurance
» Wheel & Tire Center
Old 12-05-2012, 11:10 AM   #1
kpointer25
2003 Malibu LS
Silver
Default How do you install a new coolant reservoir?
I have a 2003 Malibu LS and the coolant reservoir just recently cracked on me so I am going to replace it, only $35. It looks like a fairly simple replacement, just one bolt and a few hoses. My question is, does the coolant fluid need to be flushed or is it possible to do the replacement with the coolant still in the car; also, there is also coolant in the cracked reservoir so how do I do the replacement with fluid still in the tank?
Thanks in advance.
kpointer25 is offline   Reply With Quote
Old 12-06-2012, 08:57 PM   #2
RalphP
CMF Veteran Member
2000 Base Base
Burgundy
RalphP's Avatar
Default Re: How do you install a new coolant reservoir?
When you pull the hoses, some of the coolant will leak out. What you do is after you're done replacing the tank, refill it.
Or better, take this as a warning, pull all the hoses and replace them, and put a fresh charge of distilled water and good quality antifreeze in.
RwP
Old 12-09-2012, 12:41 PM   #3
golferwannabe
Yes, it's fairly easy. I replaced mine just last weekend as part of a coolant flush while working a clogged heater core. Mine was so old and dirty that I couldn't see the Full Cold mark.
You could drain some of the coolant from the radiator to minimize the amount of coolant in the reserve tank. Then, as you say, it's just one bolt and one plastic retaining clip - aside from the connecting hoses.
golferwannabe is offline   Reply With Quote
You may not post new threads
You may not post replies
Low coolant scott37300 Problems/Service Issues/Troubleshooting (Generation 7) 26 03-20-2013 06:32 PM
Coolant change ElantraMax Do It Yourself Maintenance (Generation 7) 3 06-09-2011 12:25 PM
02 Malibu LS leaking coolant from reservoir ciangu Problems/Service Issues/Troubleshooting (Generations 5 & 6) 1 06-03-2011 05:43 AM
Low coolant warning SidewaysLS4 Problems/Service Issues/Troubleshooting (Generations 5 & 6) 5 01-04-2011 10:20 AM
crack in break master cylinder reservoir nbma Problems/Service Issues/Troubleshooting (Generation 7) 7 05-30-2010 01:43 PM
