Help With Finding Top Speed / 2008 ecotec 4 cylinder
About two years ago, I was driving a friend home when I was pulled over. The Officer said he paced me for several miles doing 125mph. I kindly offered to show him my owner's manual for the specs, but was embarrassed when I couldn't find them! I also made mention of the fact that I had literally just entered the interstate when I was pulled over.
Fast forward: I'm finally going to court over it. I know it sounds ridiculous, but I need to find a way to introduce into evidence the fact that my 'Bu, as sweet as it is, couldn't do 125mph down hill with a tail wind, jet fuel, and rockets strapped on.
Here's my best idea to date - because I live about 600 miles away from the ticket, I figured I could go into the dealership to have them inspect my vehicle and confirm that the speed limiter is still in place. Some how, get something in writing from my local dealership as to this fact. Then, have another mechanic in the town the ticket is in testify as to the results and the meanings.
Here's where my hiccup is - I can't find the actual top speed of my 'Bu! And, I'm not 100% sure what the best way to determine what it could be is; like with using a dyno. I've seen varying numbers, from 104, to 110, to 115.
Its a 2008 Malibu LT2 4 Cylinder 2.4L Ecotec. The ONLY modified thing I have done engine related is replace the oil with synthetic and put on a K&N filter.
I'm sure there's a few people out there that have gotten that unfounded speeding ticket. And, I know we have the pro's out there that can help me figure out the best way to show my top speed in court; whether its just a technical service manual or what.
Btw, no radar.
Current:
Chevy Malibu 08' LT2 2.4L 4cyl:
Mobil 1 Full Synthetic 5W-30
K&N Hi-Flow Air Filter
5% Tint All Around
Matte Chrome Chevy Rims
15" Kicker Competition CVR 1000 Watt 2OHM Stable
1000 Watt 2OHM Stable Monoblock Amp
Black Suede on Black Leather
Oak Trim
Acura TSX 07' Sports Package, Tuned - Stock
Previous:
Honda Accord 96' LX, Sleeper
Ford Crown Victoria 97' LTD, Murdered
Toyota Camry 96' Custom Coupe, NOS
Geo Prizm 91' <-- Gotta start somewhere!
Re: Help With Finding Top Speed / 2008 ecotec 4 cylinder
Fuel cut off kicks in at 113mph i have gotten mine up to 125 but it took a couple of miles going slighty down hill. I was only able to do it once. But i have hit 113mph a few times where the fuel is shut off. I also had a drop in knn filter and using mobil1 with a acdelco filter
My '09 3.6 V6 was able to get to 115 mph on flat highway. It was still accelerating when the speed limiter prevented further speed increase.
My '11 3.6 V6 has gotten to 116 mph while accelerating on a downhill. It was still accelerating at the time as well.
Check the speed rating on your tires. It should equate to 120 mph, and if they're still stock then the limiter has been set to cut out before it reaches that limit. Laws and sue-ers being what they are, if you were able to exceed the max speed of the tires for an extended period of time and then the tires failed, GM could possibly be involved in a lawsuit. This way their butts are covered, as is yours, since you're not likely going to suffer an accident due to tire failure from excessive speed.
The officer's speedometer was or is obviously maladjusted, and if your story is accurate (I have no reason to believe otherwise), then his vision may also need checked as well as his targeting ability. (Did he incorrectly target you after discerning another vehicle exceeding the speed limit?)
Come back and let us know the outcome.
Even with a large error, you were still speeding you will probably get it somewhat reduced, but not waived.
2 years to fight for a ticket? as far as i know, in Canada, if you don't get a trial in 11 months, it's out. (as a Canadian citizen, you have the right to a fair and fast trial).
In some states, Ohio for example, the officer's approximation is valid in court, with no device. Paced you say, it's valid and it will stand. Even if he cant produce documentation over when the last speedo calibration occurred, the margin is too wide for a simple error. You were doing basically double the speed limit.
Come to the dark side, we have cookies...
The 4-cyl is electronically limited to either 112 or 117 mph because of the tires. There's no way you were driving a sustained 125, period.
Keep in mind, this information is only useful in your situation if you're trying to prove that the officer pulled over the wrong individual. If you were, in fact, still speeding at 100-115 mph, you're still screwed (and deserve it).
2009 2LT V6 Red Jewel
w/Factory Fogs, Lip Spoiler,
Black Calipers, Chrome-Tech 18s
thank you for the response davey
Current:
5% Tint All Around
Oak Trim
Previous:
re visual target acquisition; i believe he did mistake my car for an impala that went flying past me.
Current:
5% Tint All Around
Oak Trim
Previous:
welp, here in the USA, there actually are ways to challenge a visual or sight radar certification dependent on the State. but no, i actually wasn't speeding. i got on the interstate, and then two seconds later there was a deputy flying behind me with his lights and sirens. and while yes, i agree that it would seemingly be too large of a margin to overcome through sheer logic, my defense relies on being able to show that he was intentionally misrepresenting the facts in his probable cause affidavit. ergo, i need to be able to show - from chevy or another unimpeachable source - the speed at which a stock 2.4L ecotec 2008 malibu's speed limiter engages.
Current:
5% Tint All Around
Oak Trim
Previous:
Agreed. I had stock tires on at the time. There's also the mathematical discrepancy of the time he calls it in to the time he pulls me over. But, that's a whole 'nother story. He claimed I was sustaining a speed of 125mph for 3 miles continuously, with him directly behind me. I don't know if the rest of you have driven the ecotec version, but its not exactly a mach V.
Current:
5% Tint All Around
Oak Trim
Previous:
